Question about Tascam 2488 Portastudio Multitrack Recorder System
"Record" button not working
Though there is plenty of recording space on most of my five partitions, the system won't let me record. After I've hit all the appropriate inputs and set the right levels, I can't get the "Record" button to light when I push it simultaneously with "Play". It's not just an indicator light issue, because nothing is recording. Appreciate any observations.
5 Suggested Answers
SOURCE:
  • 189 Answers
SOURCE: cant restore levels
Sounds like you might have 'Fader Matching' set to something other than 'Real' mode which can cause the physical fader positions to be mismatched with the internal fader settings (useful for saving scenes, and used on the 2488 because there are no motorized faders). You can go into the 'Mixer Preferences' Menu (under the 'Preferences Menu') and check the what is set for fader matching. If it is set to 'jump' or 'catch' you should change this to 'real'.
You also might have a particular 'scene' being recalled which has a lot of saved settings that are affecting the levels.
You can refer to pages 39 and 92 (in the MkII manual) for references on scene memories and fader matching.
Hope this helps.
bd.
Posted on Feb 04, 2009
SOURCE: Play and Record button not working
I have the same problem with all three of my Tascam 2488 MKII's.
It's a software problem and starts to show up when the harddisk gets full.
Backup your song files ( something you have to do anyway ) and then reformat the entire hard disk.
Then restore the songs you were working on lately.
Before doing this rather huge task, you can copy your latest song to another partition and go on with this copy.
This is only a provisional solution.
Hope this helps !
Best regards
Posted on Feb 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: on my tascam 2488 neo,
I think if you had the manual you would know the answer to the last question.
Tracks must be a minimum of 4 seconds long (page 118)
Register and download the manual for free at audio.manualsonline.com
Search for "Tascam Portastudio 2488"
http://music.manualsonline.com/manuals/mfg/tascam/2488neo.html
Posted on Feb 20, 2011
  • 12 Answers
SOURCE: Poor Recording Level on the Tascam DP-02CF
If it works like my DP02 and DP03, you must disengage the tracks you've recorded to, get it to playback. Also make sure your Master Fader is turned up as well as the faders for the tracks you've recorded. Also on the Inputs Trim (the two knobs at the top) should be at least 50% up. I have my Dp02 at about 75% of max and my DP03 at 50%. Try this if it doesn't help, customer service at 323-727-7617 or 323-726-0303.
Posted on Aug 03, 2015
I downloaded the contents of my Tascam DR-05 to my computer because it was full, but, instead of doing it as always, by just downloading the soundfiles, I copied the file folder dr005 to my computer,
Eric have you tried to do a "Quick Format"? If I'm not mistaken when that is done, you re-format your card and the small memory in the DR05. I had trouble with mine at first but when I did the formatting after I put the bigger 2GB memory card in the DR05 worked great. I record on "All Files" too, that seems to work well also.
Hope that helps,
Patrick
Oct 14, 2014 | Tascam DR-05 Portable Digital Recorder
Problems recording on LG RHT49H HDD
There may be plenty of space in the HDD but you can only set a certain number of timers. Delete a less important timer setting to make room.
May 05, 2014 | Televison & Video
It keeps locking up
I had a similar problem before mine completely crashed. Make sure you back up your data and have a look at the space you have left on each of your three partitions. Try to delete any unused track space before recording again.
Nov 17, 2009 | Tascam 2488 Portastudio Multitrack...
I cant record
You'll see this message if you try to create a song but there's not enough disk space on the partition to create a song. Free up some disk space and try again. The manual is at http://www.tascam.com/products/dp-01;9,16,33,19.html under resources.
May 30, 2009 | Tascam DP01 All-In-One Recording Package...
I have a Thomson DTI6300-16 freeview box. I'm
This could solve problem
1. Select Menu, Set-Up, Help.
2. Press the Green button on the remote control.
3. This shows the Advanced Information screen.
4. Now press the Blue button which will prompt you with a warning box.
5. Now press the Green button if you wish to proceed.
6. The DTR will take around a minute to complete the reformat, and will then automatically restart itself.
Next do a channel rescan.
Mar 05, 2009 | Arris DCT2608
Can play video, but can't record
Have you tried to record your channels with the converter switch set to antenna?
In otherwords;
Step 1. With your converter switch set to converter mode select the Direct tv channel you wish to record.
Step 2. With your converter switch set to antenna press the record button on your DVD Recorder.
Step 3. Switch your converter switch to converter mode.
I hope that you find this solution helpful.
Feb 06, 2009 | Philips Magnavox DVD/VCR Dual Player
Sony icd-320 handheld voice record.
The erase button is on the right hand side of the recorder. When you are on the message that you want to delete, then hold the erase button down. The message will start to play and an erase message will flash. Push the erase button down again and it will delete the message. Continue to do this for each message until you have the desireable amount of free space.
Oct 25, 2008 | Sony ICD-P320 Digital Voice Recorder
Erasing Files
when you copy the files to your computer the files are still in the ws-100, you have to erase them in the ws-100 buttons after that.
Feb 29, 2008 | Olympus WS-100 Digital Voice Recorder
Pmp-4330
Do you mean voice or video recording......
whichever it is your problem maybe because of the fact that some players have only a certain limt of space alloted for recording.for example:in a normal 1 gb player with voice recording function only about 28 hrs(approx. 128 MB ) of voice can be recorded....even if there is plenty of space left in the player the player will not record voice once the full 28 hrs has been used................This recording facility can be reused by deleting the old recorded files.....
Hope it helps
Feb 27, 2008 | Coby PMP-4330 Digital Media Player
Tascam 2488 Portastudio Multitrack Recorder System Logo
113 people viewed this question
Top Tascam Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
