Question about Maytag Freezers
Maytag refrigerator not defrosting.
The refrigerator goes warm. Defrosted it manually twice, and it runs fine for a while. A repair man on a recall suggested it was the adaptive defrost control board, but would not diagnose or repair without additional service fee, even though he was already here. I am game to replace the part, but don't know how to get to it. Any help or illustrations would be appreciated.
  • 4 more comments
  • soxguy52 Jul 13, 2009
    The freezer did have frost buildup inside and on the lower portion of the back wall. The repairman from the recall moved the control for the freezer on and off a few times, and based on what he heard, said it was the adaptive defrost control board. This, he said, was behind the control panel in the refrigerator, not the freezer. I am very unclear now, as to what is where.
    It is a Maytag side-by-side refrigerator/freezer; Model # MZD2766GEW; I thought you had this information, based on the info I already put into the FixYa sight. Not trying to give you a bad review, but I had two techs putting the part in two different places. If I am shown how to get at this part, I'm sure I can replace it myself; the other technician took 5 minutes to replace the recalled part.
    Thanks
    What and where is the bimetal, and how do I determine if it is closed?
    I have tried your 2nd test method. Unplugged fridge; turned control to off; waited 4-5 minutes; plugged back in; lights went on, but nothing else started or clicked; moved control to on, and sounds like compressor started. Hopefully, this suggests the ADC board is bad. Still dont know how to get at it. I removed the top panel in food compartment, and that exposed the lights, and square area covered by another plastic panel which doesn't simply drop down. Is this evidence to replace the ADC board, and are there illustrations on how to get at it?
    Thanks
  • soxguy52 Jul 16, 2009
    Received new ADC board, and did manage to innstall it. Did not know there was a mounting piece that might not fit the new board; filed it down, and made it fit.
    While it was unplugged, I kept hearing ice falling in the freezer, so I opened up the back wall. The coils are now exposed, and I see that the freezer wall is cracked and melted adjacent to the bottom of the coil. Looks like there is a heater coil also there. Do I need to be concerned with this?
    Thanks.
    The part is in, and I will put back together. I am crossing my fingers we get some more use out of the refrigerator; don't think this was one of Maytags better efforts. Thank you FixYa.Com.
  • 3,037 Answers
The refrigerator/freezer defrost system can be checked by manually initiating a defrost cycle. There
are two methods of initiating the Adaptive Defrost Control (ADC) Test Mode.
First Test Method:
1. Turn the thermostat off for 15 seconds.
2. Turn the thermostat on for 5 seconds.
3. Turn the thermostat off for 15 seconds.
4. Turn the thermostat on for 5 seconds.
5. Turn the thermostat off for 15 seconds.
6. Turn the thermostat on for 5 seconds.
7. Turn the thermostat off.
In 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal closed). NOTE: The test mode will terminate when the bimetal opens. If the refrigerator/freezer is already in defrost, Test Mode can be terminated by unplugging the refrigerator/freezer from the wall outlet and waiting 30 seconds before plugging it back in. The refrigerator/freezer should immediately go into cooling mode if the thermostat is closed.
If this first test procedure fails to make the ADC initiate a defrost cycle, try the following procedure to make the ADC begin the Test Mode.
Second Test Method:
1. Disconnect the refrigerator/freezer from the wall outlet for at least 30 seconds.
2. Turn the thermostat off.
3. Reconnect power to the refrigerator/freezer.
Within 3 to 8 seconds the ADC should turn on the defrost heater (with the bimetal close). If the unit fails to go into the defrost mode during this test, the problem may not be with the ADC. A defective bimetal may be the cause of the failure. The ADC will only go into a test mode if the bimetal
is closed. If the ADC senses an open bimetal it will return to the cooling mode within 3 to 8 seconds.
HELPFUL HINT: Upon entering the Test Mode, the relay mounted on the ADC board should turn off the compressor and turn on the defrost heater. Listen for the relay to click.
If the relay clicks one time when entering the Test Mode, check for continuity in the defrost heater.
If the relay clicks two times, check for an open bimetal.
A helpful schematic of the wiring can be found at the following website link http://www.applianceaid.com/images/mayadaptive-defrost.JPG
The control board will look something like this picture =>
http://www.applianceblog.com/archives/MaytagAdaptive.jpg
This is all happening in the fresh food compartment, up top which is where you will find it. It is very failure-prone, so you are definitely not the first, the relay in it is usually the failure. Be sure to unplug the fridge before disassembling or you could get a nasty shock. Been there, done that.
If you don't defrost the fridge manually, then you should let it defrost on its own by turning it off and leaving the freezer door open. Usually, I take apart the freezer and defrost the evaporator. But, if you can get by without it for a few days, just let the fridge defrost on its own.
Benjamin
Posted on Jul 13, 2009
  • 3 more comments
  • Benjamin Patri
    Benjamin Patri Jul 13, 2009
    thanks, did not have that info on the model number before.
    Its located inside the top console inside your refrigerator section
    that mounts to the inside refrigerator ceiling, that console will drop
    down, then you can change it.
  • Benjamin Patri
    It is a little lever looking piece of metal that has two types of metal on it making it bend and come into contact with another piece of metal depending on the temperature because of the thermal properties of the two different metals that make up the bimetal. It should be clearly visible and acts as a lever like I stated before. It is directly on the adaptive defrost control board
  • Benjamin Patri
    The bimetal is closed if the free end is in contact with another metal contact
  • Benjamin Patri
    Yes, this should be enough evidence to replace the ADC. That last panel should pop down, might need to pry it out with a flat-headed screwdriver or butter knife or similar object.
  • Benjamin Patri
    Benjamin Patri Jul 16, 2009
    If the crack goes all of the way through, then you definitely have a problem, I would try sealing it up as best as you can. As long as the heater coil isn't damaged, you are fine there too. As long as you can keep water from going into the insulation by sealing up the crack, this fridge should last.
  • Maytag Master
  • 19,396 Answers
If the problem is that when you program the refrigerator to defrost , it does not do defrost, then it is the defrost control board.
If instead you have ice buildup at the back of the appliance, and the defrost system is not working, then you need to test the defrost heating coil, defrost timer, and the fan system. If all this is ok, gns.o for the defrost control.
All parts are located behind the freezer firewall.
The defrost element (coil) and defrost thermostat are tested using a multimeter on Ohms to read impedance. The fan motor is tested reading voltages and checking if it run.
The test must be done by a repairman.
Entering model number here you can get parts and diagrams for your appliance.
Regards.
  • Ginko
    Ginko Jul 13, 2009
    If the tech moved the control for the freezer on and off manually a few times, then it is the control board.
    As I said, If the problem is that when you program the refrigerator to defrost ,
    That is what the technician did.
    To get part diagrams and location you need to give me the model number as printed on the service tag.
    Sorry that you gave me a bad feedback.
    Regards.
The freezer side of the unit will freeze until it freezes over and will no longer keep the freezer frozen. The freezer then has to be defrosted so it can freeze again.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
May 08, 2011 | Maytag Freezers
I had no problems with my freezer but now the red light has come on and my freezer has defrosted any ideas??
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Jan 13, 2011 | Maytag 15 cu. ft. / 425 liter Upright...
I have a kenmore upright frost free freezer mod #253.26432100. A couple of months ago everything defrosted and the unit was not running at all. I unplugged it cleaned it and plugged it back in, it turned...
You have a problem with the ADC.
Frigidaire has also jumped into the market with an adaptive defrost board. The fresh food section light switch and light bulb must work. To initiate a defrost cycle, open the door and push the light switch in and out 5 times within 6 seconds. The compressor and fans should shut off and the defrost heater should come on. Open the door and push the light switch in and out 5 times within 6 seconds to remove the refrigerator from the defrost mode and back into a cooling mode.
This product comes equipped with an Adaptive Defrost Control (ADC). To activate manual defrost, press and hold the Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. A "d" in the freezer temperature window and "F" in the refrigerator temperature window will display when the heater is activated. To deactivate manual defrost, press and hold Freezer temperature UP (WARMER) key while pressing the Fresh Food temperature DOWN (COLDER) key 5 times within 6 seconds. "d" and "F" will be displayed until the defrost cycle is complete. (approx. 8 minutes)
Nov 23, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
I have model No FZA34G - Frost free freezer. The red light marked "high temp" has come on and all the food has defrosted. I can't find the manual.
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
Sep 30, 2010 | Hotpoint Freezers
Our freezer will freeze water but not food. top shelf frosts over and the other shelves stay clean. food in freezer all defrosted
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 04, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
I put in 35 quarts of applesauce last night and this morning everything in door and top shelves were defrosted. Is it not working?
If you put 35 quarts of warm applesauce in there you probably defrosted it iwth that....I as long as it seems to be running and you can feel cold air I would give it more time...
heatman101
Sep 03, 2010 | Freezers
Refrigerator is not cooling
Good day,
You will need an ohm meter to check the parts.
Your defrost system has failed.
It is made up of 3 components, 2 of which are located behind the rear panel in the freezer compartment.
Remove the rear panel. There is a cooling coil, that has a calrod heating element that runs along it's bottom. As well there is a defrost thermostat ( a small round 1" disk) which is located on the top of the same coil. Both should be checked with an ohm meter to test for continuity. The heater should read no more than 30 ohms, the thermostat ( IT MUST STILL BE COLD BELOW 30 DEGREES) should read zero ohms. Note: The heater rarely fails, the thermostat has a high failure rate.
The third item is a timer, or a solid state adaptive defrost control. Depending on age, and model, it is located , behind the kick plate on the bottom front.
Or, in the fresh food compartment on the roof.
If it is a timer, you can turn the timer shaft when the machine is running until the machine shuts off. With it still turned on, wait 40 minutes.
If the machine turns itself back on, the timer is O.K. if not, the timer is bad, and needs replaced.
If the Main heater checks O.K. and it has a solid state control, then replace the thermostat in the freezer compartment, and the solid state board.
Below is an excellant tutorial on defrost systems.
http://www.appliance411.com/faq/howdefrostworks.shtml
Thank you for using FixYa
Jan 20, 2010 | Nor-Lake Freezer Norlake Refrigeration 6'...
Gibson Upright Freezer
Is it a self defrosting? Or not? And how did you defrost it?If you scraped and chipped the ice away, you may have poked a hole in the evaporator and the refrigerant (freon) leaked out.
Jan 03, 2010 | Frigidaire Freezers
Gladiator fridge/freezer-freezer not cold enough, stays at 10 deg
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Dec 12, 2009 | Whirlpool 19.6 cu. ft. Upright Freezer...
Freezer frost
That you have to 2 defrost your freezer it's normal depending of many factors. Do you open it often, is it in a warm place, is the food that you are putting in it is warm? many factors contribute of building up frost faster.
Francois
Dec 29, 2008 | Freezers
Open Questions:
Freezers Logo
467 people viewed this question
Top Maytag Freezers Experts
John Tripp
John Tripp
christian nielsen
Ismael Rodriguez...
Are you a Maytag Freezer Expert? Answer questions, earn points and help others
