Question about Honda Jenny K5HGA-17P 5.5 17 Gallon GX Gasoline Engine Recoil Start Gas Compressor
How much fork oil do i put in my 02 954 blade
    Sergeant:
  • 384 Answers
Fill oil to the bottom of the drain plug hole.
Posted on Jul 13, 2009
Yamaha 1980 MX 80 Front Fork Disassembly?
Start off by removing the forks from the bike, then remove the top caps (bolts) from the forks. Once removed take out the spacer and fork springs from the forks. Tip them upside down to get the fork oil out. Now with the forks empty from fluid and springs you will compress the forks all the way to make them as short as possible. You will need a fork dampening tool or a air gun to split the forks by removing the bolt inside the fork tubes. Once this is achieved you can pull the forks apart and replace the fork seals. When putting fork oil back into the forks if you are not sure how much to put back in, just compress the forks all the way down and fill each leg 6 inches from the top. That amount works for just about any motorcycle with conventional forks. Use 10 w fork oil.
May 23, 2018 | Yamaha Motorcycles
How much fork oil do I put in each leg of my zephyr 1100
Is you have taken the forks apart and changed the fork bushes, ie forks are totally dry, you will need about 520ml in each fork leg. When refilling and will the springs removed, add about 550ml per leg, the stroke the forks numerous times to expel any excess air. Then with forks compressed the oil level should be adjusted to 119mm from the top of the fork to the oil, ie the air gap to the oil. The add springs and spacers and reassemble.
Red zed.proboards.com
Sep 01, 2011 | 1992 kawasaki Zephyr 1100
How much fork oil is required in the front forks of a 2000 suzuki 800 intruder and how do you measure if you put too much in. The guy at cycle gear where I bought the fork oil said to top it off or fill...
Hi, all model VS 800 from1992-2000 take the same amount of oil in the front forks, using 10 weight fork oil measure into a clean measuring device or mark the side of the oil bottle 413 mls, pour this caerfully into 1 fork, and the same amount into the other fork, 413/413 cm (3)
May 09, 2011 | 2000 Suzuki VS 800 Intruder
How do u fill the down tubes on a hoda shadow
First of all do not add oil to your front forks with out draining them first. If you over fill your forks with oil you will damage your forks. To change your oil in your forks, first center stand the bike and lift the front wheel by putting a jack under the motor. Remove the front wheel and axle and put a pie tin under the fork tube. Reach up into the bottom of the fork tube with a hex key and loosen the screw but do not remove. Now take the air pressure cross over tube off, this will allow you to unscrew the fork tops( On some bikes you may have to put a towel on the tank and unbolt the handle bars to get them out of the way.). Pull the screws out of the bottom of the forks and gently pull down the oil should come out now. If you need new fork seals take the lower tubes off and replace(You may need to take off the fender and hang the calipers with wires.). Turn the lowers over and dump out the oil and reinstall fork lowers. Snug up screws and sealing washers on the bottom of forks you can not tighten till you put on fork tops. Now pour in measured amount of oil, again do not over fill. Put on fork tops and air crossover tube. Now tighten screws on bottom of fork. Finish reassembling bike.
Jul 14, 2010 | 1989 Honda VT 1100 C Shadow
1993 Honda CBR 900 RR Fireblade fork oil capacity
Hi, Grantrac for this scenario you will need your service/owners manual if you can't find the best tool you ever bought for your Honda, despair not, for a mere zero $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Honda CBR 900 RRW CBR 919 Fireblade SC33 98
http://www.fireblades.org/forums/honda-fireblade/56114-94-900rr-fork-oil-how-much.html
Honda CBR900RR Service Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda CBR900RR Fire Blade Owner Manual
Jan 30, 2010 | 1993 Honda CBR 900 RR Fireblade
Front suspension must be refilled with oil, how to do it?
There is a drain plug at the bottom of each fork. Just drain them and put the plugs back in then take the caps off the top of each and put in the propper amount of fork oil. You will need actual fork oil, so when you get it ask the shop how many cc's of oil to put in each fork.
Oct 02, 2009 | 1989 Yamaha Xv 250 Virago S
Can you tell me how much oil to put in an en500 forks please, Andy
If you never have put for oil into a set of forks, yes you have to check both forks. I would suggest treading lightly. If you have time and a place to block the bike as well as a manual you can do it.
Are you adding oil because the seals are leaking or do you have excessive stiction in the fork? If the seals are leaking, you will have to pull the forks and add new seal and put in exactly the right amount oil.
Do you have air seat or is it a closed fork?
For you en500 you should have a volume of oil in your service manual.
Aug 17, 2009 | 2005 kawasaki EN 500 Vulcan
Hair Clippers not clipping
for Shorty8 adjust power screw,check connector fork,if too tight losen tension inside the clipper
Aug 28, 2007 | Andis 01690 Hair Trimmer
Honda Jenny K5HGA-17P 5.5 17 Gallon  GX Gasoline Engine Recoil Start Gas Compressor Logo
95 people viewed this question
Top Honda Air Tools & Compressors Experts
John Trevino
Tim Venetis
Are you a Honda Air Tool and Compressor Expert? Answer questions, earn points and help others
