Question about Acer Aspire 3000 Notebook
Aspire keyboard not responding
I think I figured out the issue for my aspire keyboard. Found out how to clean the fan and also how to disable the battery. Why dies a bad battery screw up the keyboard.
  • rdial54
    rdial54 Feb 28, 2014
    always clean out key board. Hold lap top carefully upside down and with soft paint brush lightly dust keys. Works on desk top key board too.
  • 335 Answers
Bad battery does not cause keyboard issues. Tell me more about the problem and I can help. I am an acer technician.
Posted on Aug 09, 2009
I have a Acer aspire one 1012 that had a broken screen, I replace the screen and then the keyboard would not work. I replaced the keyboard and restore the computer to factory default but still can not
how you did the restore? USB keyboard?
See if it is disabled by BIOS. you can check this with your manual.
Try with FN+ i think it's F6 you have probably some markings on keyboard.
Mar 18, 2013 | Acer Aspire One Netbook
Touchpad not responding in netboook
There's a little button right above the touchpad. If the light on this button is orange, the touchpad is disabled. Press it again until the light is white again and your touchpad should work.
Nov 17, 2009 | Acer Aspire One Netbook 8.9" Notebook
My laptop keyboard does no work so i cant get past the password on my laptop
is this a bootup password that comes up right away when the power is turned on? If so - then the keyboard, mainboard or the flex cable connecting the keyboard to the mainboard is faulty.
I would reconnect the keyboard and clean the flex cable and its connector, I've found sand inside two laptops so far that had keyboard issues... cleaning the flex cable and the connector solved the issue in those cases.
If that doesn't help, you can try another keyboard or a usb keyboard, if both don't work then the issue is either the keyboard connector or the mainboard is failing, which isn't uncommon for acer, I have a 3000 series laptop that has the same problem - keyboard doesn't work, usb doesn't work either.
Outside of warranty are you?
Sep 14, 2009 | Acer Aspire 5633WLMi Notebook
Another Acer 5100 with mouse/keyboard not responding
Replace Battery with a new one, i have seen this issue on the 1650 series as well, dont know why it works but it does
Jun 06, 2009 | Acer Aspire 5101WLMi Notebook
Keyboard doesn't respond
This world be a issue with the main board if you get nothing but neeping on both inputs, how about trying a usb keyboard to see if that shores it up if not you going to need service on this Acer..
May 22, 2009 | Acer Aspire One PC Notebook
Acer Keyboard Cursor moves without my knowledge
Someone has remote assistance to your computer. Go into Control panal and turn "Remote Assistance" off
Apr 14, 2009 | Acer Aspire 5920-6423 Notebook
Laptop Mousepad and Keyboard stuttering, slow
This may be a battery power monitor issue. Try disabling the "Mircosoft ACPI- Compliant Control Method Battery" device. This is located in Control Panel-->System-->Hardware Tab-->Device Manager-->Batteries. Had similar problem with 2 Acer Aspire series laptops (diff models). 2 and 3 year old. Original batteries (both still hold charges for 1.5 hrs of normal usage). Running WinXP, one with SP2 and other had SP3. Both came in the last month with slow jerky TPAD function and nearly non responsive keyboard access. Checked the usual; virus, spyware, hijacking, driver conflict etc. Cloned drive and factory installed..still same problem with kb & mouse. However an external USB keyboard and mouse functioned normally (no lag). Noticed with Battery removed kb & mouse was normal. Finally found disabling ACPI control battery device resolved this issue while allowing laptop to run on either battery or AC.
Jan 30, 2009 | Acer Aspire 1640Z Notebook
Keyboard + toucpad freezes
Might seem ovious but you may want to try Acer support and look for a new Driver.. Also check under Control Panel...Mouse options... and also check device profiles to make sure windows isn't loading a "docked profile which may disable touchpad and laptop keybaord use.
Feb 21, 2008 | Acer Aspire 5670 Notebook
Keyboard and touchpad problem
seems like the board is screwed! or may be its just the keyboard & touchpad controllers, either way its a h/w problem since u've already mentioned that u've tried reinstalling windows and the problem still persists. i'd advice that you take it to service center.
Apr 24, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 keyboard failing
The problem is the battery as mentioned before. Disabling "Microsoft ACPI-Compliant Control Battery Method" should solve the problem of the keybord and the mouse, this is, because the driver dosen't work properly with a bad battery. I think it fires a lot of hard interruptions that are blocking the keybord and the mouse interruption to the system (each time a key is pressed an interruption is send to the processor... if the battery driver sends a lot of interruptions, the key interruptions don't have time to be processed in time - that explains the fact that the system responds to a key press is that bad)
Apr 06, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 3000 Notebook Logo
224 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
