This problem should be removed because:
Problem with Microsoft Office Access 2003 (077-02871) for PC
MS Access: Zero value to display as "New"
MS Access: How do I get any expression that is equals to zero to display as "New" instead of 0?
Solutions (1)
Is that field a resultant of an expression or it will be filled manually? If it is a manually updated field then use the following expression in the code builder.
If ok.Value = "0" Then
ok.Value = "New"
End If
If the field is a resultant of an expression then add some more lines similar to above to get required results.
MS Access
I am able to export data from a MS Access Table to a text file in C Dirve. Howwver, before some columns I must append three zeros. For...
FORMULA PROBLEM IN MS EXCEL
WHEN I SUM THE CELLS VELUE THEN IT SHOW ME 0(zero) BUT IT'S TOTAL IS NOT 0(zero)
Sometimes when I use a formula in Excel 2003 it
Sometimes when I use a formula in Excel 2003 it will not calculate - it is as if the formula does not exist. an additional problem is that...
in my Ms excel 2007
in my Ms excel 2007 can't save.how can i fix it
Add Your Solution
Microsoft Access Report Creation
Creating a report in columnar form (details / titles down the left hand side). I want multiple columns to appear on the...
how to use validation rule
how to use validation rule in microsoft access?
what is the maximum number
what is the maximum number of records that Access 2003 can process in a query? I am finding that when I bring a large...
i wants download ms access
i wants download ms access 2003
See all Microsoft Office Access 2003 (077-02871) for PC Problems
Fix-O-Meter
85
85 people viewed this problem
- 0 people are following this problem. Be the first!
Top Microsoft Business and Productivity Software Experts
Verification:
Please enter the characters below to complete your post
Can't read it? Try a different one
this code should be added to the "afterupdate" event of the field.
here "ok" is the name of a sample field.
