Question about RCA 20F512T 20" TV
TV just turns off
Everytime you turn it on it will turn off. Sometimes after a few seconds other times after a few mins. It seems to be getting worse. Any suggestions. After checking the manuel I double checked all timers and they are all off. The TV is only a year 4mos old. Any suggestions
  • cj4126 Apr 27, 2008
    had the same problem the n was messin around in menu acidently put on fba lock of something light comes on but wont turn on what do i do
  • Anonymous May 26, 2008
    THE TV CLICKS ON AND OFF CONTINOUSLY.
Most common reason for this problem is dry joints, ie cold/bad solder joints.
Capital98
Posted on Nov 16, 2007
How can I fix my tv? it won't turn on.
It seems like its a power supply failure
Mostly bad capacitors
the fact that it was getting worse by the time proves that
The first thing to do if you are not an expert is to unplug it
and let it for a few minutes thn unscrew the back with a proper scredriver and keep unscrewing until you see the power supply board and the mainboard
The one that the power cord usually goes is the power supply unit
there you should search for bad capacitors
(you can take an example from the photo attached)
you should replace them with the same by buying them from an electrics store and using a soldering unit
----be aware that capacitors are energy storages and maybe even after a few seconds or minutes they might haveelectricity in them
secondly if you had never touched a soldering desoldering unit before ----you might damage the boards so bad they wont be fixable even if you send them afterwards to an expert
and
----last electricity kills so be very carefull )
Aug 15, 2014 | Televison & Video
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
The Television will not stay on
LOOKS LIKE YOUR CONVEGENCE IC ARE SHORT UNWELD BOTH IC AND TURN TV ON IF IT STAYS ON 450 DOLLASR TO REPAIR
Jun 03, 2010 | Hitachi 43F300 43" Rear Projection...
TV searches, but will not turn on.
Ur tv have problems,etheir the Tuner signal board or the LCD inverter board.After u turn on the tv,no picture turn tv off/on 3-4 times each time wait a few mins.see if the picture come on?Than it ur Tuner board have problems.If u turn on the tv and get just a flashes of a picture about 30 or 40 sec.than just disappear,than ur LCD inverter board is the problems it dead.
Apr 16, 2010 | LG 62SX4D 62" Television
TV turns off by itself
Thus the line connected to a surge protector or some kind of line protector. This can be consider.
Or if this is a crt type tv. This could be a fault on high voltage section. Horizontal output transistor or flyback. But check also for loose connection/solder crack. That clicking sound may be the relay in action.
hope i give some correct input.
Apr 23, 2009 | Samsung PCL5415R TV
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Tv powers on, but turns off after a few min
somone with some sort of tv knowledge told me that sometimes people dont realize t but moisture builds up inside and it needs to be dried back out
Jan 28, 2008 | Televison & Video
RCA 20F512T 20" TV Logo
57 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
