Question about Dyson DC07 Animal Bagless Upright Cyclonic Vacuum
Need to replace the suction hose, need help reattaching
I have a hole in my suction hose and need to replace it. which part is it and how do i replace it
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 83 Answers
You need to purchase a new hose - you can search for it online (DC07 External hose) or you can simply call the Dyson helpline and order it through them.
Posted on Jul 29, 2009
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 | Vacuums
Shark transformer vac model ep602 will not suction from the floor brush, but will suction from the flexible hose. Dust cup and filters are clean. Do I need to replace the floor brush? Unit was purchased...
Has the floor brush ever worked for you? I thought it was broken at first too. The hose has to be inserted in the appropriate hole in the side of the machine. The hose is where all the suction comes from, when you put it in the side hole it will provide suction for the floor brush.
Oct 11, 2010 | Vacuums
No suction
I wonder exactly where you've looked for blockages... The fact is that if the vacuum motor is working (you would surely have said if it wasn't) there should be suction. The question is: why isn't it getting to the end of the hose? First thing you can try is to remove the hose from the hole where it enters the top of the bag compartment - check for possible obstruction at that point, then switch on and hold your hand over the hole to check for suction. If there's suction there, then there definitely is an obstruction in the hose. If there's no (or very little) suction at the top of the bag compartment, check the filter at the bottom of the bag compartment (below the bag). I assume you have been using a bag and filter! If all these things pass the test, then you have a serious problem with the vacuum turbine and you'll probably need professional help.
I hope this is useful. If so, please remember to rate my response. If you need more advice, post a reply here and I'll get back to you as soon as I can. Good luck!
Mar 12, 2010 | Sebo 9803AM Upright Vacuum
There is minimal suction in the hose. Nothing appears to be blocking the hose.
You most likely have a gasket out of place.
1. On the bottom, there is a panel held in by two screws. Open that up. Inside you will see a white gasket that should be aligned with the hole. If it is not aligned, you will not get good suction.
2. The other gasket will you require you to take out the two screws on the blue cover (at the base of the unit where the dial is). You will see a black plastic tube with two clear tubes attached. Remove the two tubes. remove the screw holding the black plastic tube in. Inside is a red gasket. Ensure that is in the correct place. Reattach screw + clear tubing. Reattach blue cover.
Let me know if this helps.
Feb 01, 2010 | Bissell 9200 Upright Vacuum
Nilfisk A300 Suction problem
Mate - don't know if this will help - I had the same symptoms - saw your question through google - no answers, then I moved the red slider button on the top of the vacuum and hey presto! It has adjustable power. Man I felt like an idiot!
Jan 30, 2010 | Vacuums
No Wind Coming Out of Dirt Devil
The suction hole will never have wind coming out of it, it is for suction. To switch from floor to hose, turn the control knob labeled floor / hose.
May 02, 2009 | Dirt Devil Vacuums
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Eureka Central Vac-Sweeper -Model B1501
I like using a Wire Clothes hanger to work the stuff out with. If you fashion a fish hook of sorts out of the wire, you can catch things inside the brush head and pull them out.
Oct 24, 2007 | Vacuums
Dyson DC07 Animal Bagless Upright Cyclonic Vacuum Logo
107 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Samyfam
Samyfam
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
