Question about Ricoh Office Equipment & Supplies
Ricoh mpc 2500. apparently i took out the pcu unit, and dumped all the developer out thinking this would solve my black lines issue. well if i buy a new one, would that fix it, or would i need a technician come out and put it in.. How can i fix this without paying $1,100 for a new pcu unit? thanks
    President:
  • Ricoh Master
  • 990 Answers
Hello sir; You did it right,but only missing one place that is transfer belt unit, there have a cleaning unit (at the end of the unit) just replace cleaning blade should take care your problem.
Posted on Jul 13, 2009
SC 491 error message
sc 491 is error signal is detected for 0.2 seconds when charging the drum or development.
• High voltage leak
• Broken harness
• Defective drum unit or development unit
• Defective high voltage supply unit
Oct 19, 2016 | Ricoh Office Equipment & Supplies
MPC 3503 Splashes slight magenta toner on prints out and copies. Given the white paper light magenta colour as if the paper is a colour paper and this make my magenta toner to finish so fast than others
You are having some time of voltage issue or bad PCU. Would star replacing the Magenta Photo Conductor Unit (PCU). If issue is not fixed with that you are going to need a tech to take a look at your developer and make sure you don"t have a bad Power Supply.
Aug 14, 2016 | Ricoh Office Equipment & Supplies
Ricoh aficio c420dn wont print black
Hi, my experience with this machine is that the gear that drives the black pcu breaks or cracks. Usually caused by the pcu being too hard to turn. I always turn the developer gear in the pcu before installing it just to loosen the toner.
Mar 15, 2017 | Ricoh Aficio Office Equipment & Supplies
I have a Ricoh Aficio CL3500N When I print a vertical page there are thin black lines going down the left side of the page. What causes it?? And what can I do??
Hi, thin black lines are most likely (but not definitely) caused by something in the black PCU (photoconductor unit), either the drum or the charger. Replacing the black PCU will likely get rid of your lines. The Ricoh code for a black PCU if you don't already have one is 402448.
Jan 29, 2011 | Ricoh Aficio CL3500N Laser Printer
Ricoh Aficio AP3800c--message to replace black PCU, have done same and still get message?
This must be done before drum is replaced.
Resets counter.
Start the SP mode and execute the
New Unit Set:
• PCU: SP5-999-001 ∼ 004
Feb 03, 2010 | Ricoh Aficio AP3800C Laser Printer
Sc491 error on ricoh MPC 3500
Sc 491 straight from manual
High voltage power: Drum/ development bias output error
An error signal is detected for 0.2 seconds when charging the drum or
development.
 High voltage leak
 Broken harness
1. Check or replace the harness.
2. Replace the drum unit or paper transfer unit.
3. Replace the high voltage supply unit.
Nov 16, 2009 | Ricoh Aficio CL3500N Laser Printer
Installing PCU on Ricoh Aficio MP2510.
Hello sir; The procedure little bit difficult, Remove PCU, remove the front cover(two screws), remove the rear bushing by remove one lock ring, remove the front joint, remove the developer hopper cover( 3 hook ) dump the old one out vacuum entire unit ( magnet roller ), fill in new developer, replace hopper cover, after replace PCU and developer you need to do some simulation, #1, press "clear mode" "107" and press hold "clear/stop" for 3 seconds, then touch screen on "copier sp". #2, enter sp3902-9 to1 for black drum unit, sp 3902-10 to 1 for yellow, sp3902-11 to 1 for cyan, sp3902-12 to 1 for magenta, #3, enter 3902-005 for black, 3902-006 for yellow, 3902-007 for cyan, 3902-008 for magenta, set 3902 to 1 for each of these if replaceing developer, press "exit" twice to end the service.
Sep 18, 2009 | Office Equipment & Supplies
Ricoh Aficio CL3500N PCU issues
These machines were actually made by Panasonic and they eat PCU's there is no rhyme or reason, they just do. I would replace all of them as soon as possible. These printers were pretty much interim technology for Ricoh until they developed thier own engine. I highly recommend the new 400 color series, low cost per page, vg color and consumables last a long time!
www.mfpsolutions.blogspot.com
http://www.websitetoolbox.com/mb/copierquestions
Jan 19, 2009 | Ricoh Aficio CL3500N Laser Printer
Black lines down page
It must be the black pcu , the cleaning blade picks up dirt and causes these lines , it can also be the black developer giving you trouble , if you want be very carefull aand strip the pcu open you will see the lines only on the inside and not from outside , then you will know if it is developer or the cleaning blade
Oct 24, 2007 | Ricoh CL4000DN Laser Printer
Ricoh 3310L Fax machine - 'Time to change PCU'
You need a new drum. Photoconducter unit. Cost about 140.00 I sell them or you can shop on EBAY
Aug 10, 2007 | Ricoh 3310Le Fax Machine, FAX3310Le...
352 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
Michel
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
