Question about GE Nautilus 24" Built-in Dishwasher
Can i replace a white door with a black door - GE Nautilus 24" Built-in Dishwasher
    President:
  • 1,136 Answers
Hi, Please get me the model # and I can look this up for you to see if the white door is available.
Thanks
Vic
Posted on Jul 13, 2009
I need a wiring diagram for a viper 5701 alarm/ remote start to 2000 celica. I got it used with no instructions
http://www.broadbandreports.com/r0/download/1719726~1dde657f739f4c4af788bc21302e8a8b/Viper-5701-NewStyle-Install.pdf
Constant 12V+ Black/Red and White Ignition Switch Harness Starter Black/White Thin Wire in Ignition Switch Harness Ignition Black/Orange Ignition Switch Harness Ignition 2 Blue/Red Ignition Switch Harness Accessory Gray Ignition Switch Harness Tach Brown/White ECM Brake Switch Green/White Brake Switch Trunk Pin Light Green (-) Switch or Dome Light in Trunk Parking Lights Dark Green (-) Parking Light Switch Head Lamp Red/Blue (-) Right Side of Center Console at ECU Factory Disarm n/a Door Trigger Red/White (-) Driver's Kick Panel Door Lock Purple/White (-) Switch in Center Console Door Unlock Pink/Black (-) Horn Wire Blue/Black(-) Steering Column Windows Up LF=Green, RF=Blue (passenger's switch main) Windows Down LF=Red, RF=White/Blue
Dec 30, 2014 | Vehicle Parts & Accessories
GE Timer #15086 has red, white, green, black wires. Wall has white, black & black wires and switch sits between 3 other light switches. (I am replacing the current timer which only has 3 wires and...
GE 15086 programmable timer replaces single-pole switch only.
Single pole means 1 device turns Load on-off.
3-way is where 2 devices turn Load on-off, for example 2 switches located in hallway.
Your existing timer has white, black and blue wires.
Your new timer has white, black, red and green wires.
Green wire connects to bare ground wire in every occasion with every wiring device.
Electricians don't guess, they test the other wires.
Remove old timer.
Separate wires for testing.
Turn on power.
Tape ordinary tester leads to wood sticks to keep hands away from power.
Test each wire to bare ground wire.
Tester will light up on Hot wire. The Hot wire will connect to timer black wire.
Now test Hot wire to each other wire (except bare ground)
Tester will light up on Neutral wire. Neutral wire connects to timer white wire.
The remaining wire connects to timer red wire.
After connecting timer, push manual override button to check that Load turns on-off.
Manual override on 15086 is the door that covers buttons > use door as push button to check Load.
Next, program the timer.
Programming is straightforward and similar to other timers.
If you have a problem, add a comment.
You can also take advantage of Fixya phone support. Expert will walk you through the steps for a price.
Dec 22, 2010 | Hardware & Accessories
My door keeps beeping saying it is open when it's not.
Replace the door switch, they are collapsable and eventually compress too far.
to test, remove the switch and see of warning is silenced.
Jun 22, 2010 | 1998 Ford Windstar
Replaced photoeyes but the lights on them are not on. The door will not shut unless you hold the button.
Make sure it is wired correctly. Did you also replace the wiring? The solid white wires go to terminal 2 and the white wires with the black tracer go to terminal 3.
May 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
I have a GE nautilus dishwasher Model GSD4000N10BB that is white and I would like to replace the white door with a black one. Is this possible and how much will a new door cost?
hi, I believe it is possible to change the colors. I looked up your model # and found only black listed. I then changed the 2 end letters to "WW" and found the doors are white. If you would call C.E. Sunberg @ 1-800-621-9190, they will be able to confirm that this is possible.
I hope this helps you. Please let me know.
Thanks
Vic
Jul 13, 2009 | GE Nautilus 24" Built-in Dishwasher
Need to know wiring scheme on back of garage door opener
join both wires the white one with the white one, and the white with black strip, with the same other, then connect it on the back of the motor the white wires with the white terminal (a white square) and the white with the black strip with the black terminal (a black square) .. check that both leds of sensors are on
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Wiring diagram to hook-up remote starter on 1996 dodge caravan
Constant 12V+ Red or Pink/Black - Ignition Switch Harness
Starter Yellow - Ignition Switch Harness
Ignition Dark Blue - Ignition Switch Harness
Ignition 2 Black/White - Ignition Switch Harness
Ignition 3 Dark Green/Red - Ignition Switch Harness
Accessory Black/Orange - Ignition Switch Harness
Tach Gray Or Blue/Tan PCM Coil 2.4 Liter - Engine
Neutral Safety Wire Black/White - Power Control Module
Brake Switch White/Tan - Brake Switch
Trunk Pin Tan/Black - 40 Pin Connector at Fuse Panel
Parking Lights Light Green/White (-) - Head Light Switch Harness left of Column
Head Lamp Green/Orange - Light Switch
Factory Disarm White/Dark Green - (665 Ohm) left Connector bottom of Fuse Panel
Door Trigger Brown/White (-) - Lower right Gray Connector at Fuse Panel
Door Lock White/Dark Green - BCM at Fuse Panel
Door Unlock White/Dark Green - White Connector B58 Connector
Horn Wire Black/Red - Steering Column
Windows Up LF=Light Green, RF=Brown/White, LR=Blue, RR=Gray
Windows Down LF=White, RF=Purple/White, LR=Red/White, RR=Dark Green
Your R/S instructions should tell you what goes where.
Thanks for using FixYa - a FixYa rating is appreciated!!
Jan 31, 2009 | Vehicle Parts & Accessories
Basic wiring for craftman garage door opener
from left to right..
1. red. to wall button
2. white . common to wall button and white wires of sensor.
3. black. white with black strip of sensors
Jul 08, 2008 | Sears Craftsman LiftMaster Chamberlain...
GE Nautilus 24" Built-in Dishwasher Logo
65 people viewed this question
Top GE Dishwashers Experts
Mike
Garth Jackson
jdthefixer
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
