Question about Symbol Telxon PN: FlatRepair-PTC960X-LVL2 Level 2 Flat Rate Service Repair. Includes major assemblies. Does... (FLATREPAIRPTC960XLVL2) Barcode Scanner
TELXON 610 frozen
I have a TELXON 610 that is showing only 67> on the display, and won't let me reset it. I also don't have its ID #. Is it possible to unlock it.
Thanks.
Tanya
    Novelist:
  • 75 Answers
Hi Tanya,
That is the base TCAL operating system, version 6.7. You can reset it by
  • turning the hand held off
  • holding down the bottom left and right buttons
  • switch on and holding down the on/off key till it reboots.
If it still comes up with 67> then try [6] and then [Enter] key. This lists the applications they will end it .y then hold [5] to run.
If nothing works then either the ARC is faulty or application was RAM loaded and has been lost.
If you need any further assistance then please contact us
www.biastechnology.com
helpdesk@biastechnology.com
Posted on Sep 11, 2009
WOODS 59018 TIMER WIREING CORRECT INSTALLED WITH POWER OFF NETURAL GROUND UP TO CODE LOAD /LINE PROPER.NEW OUT OF BOX WON'T RESET. STEP 1 LAMPS LOAD SIDE GOOD. RETIRED CONSTRUCTION ELECTRICIAN
I don't have answer for defective timer. Buy another timer if everything below checks out:
59018 7-day timer has limited 1 year warranty, and appears to be made by Tork
Timer is for 120Volt single-pole only.
Rated for 1000 watt tungsten, 8A ballast, 1/4 HP
Push reset button with toothpick > not necessary to press-and-hold other button to accomplish reset.
After reset, 12:00 am Monday should display.
Programs are deleted. Reprogram timer.
To check, change and delete specific programming, press PROG key until selected program displays, and then set new programming >>> or press-and-hold MODE button and press PROG button again to delete selected program.
Timer has non-replaceable 30-day carryover battery and does not lose programming after power outage, and will retain programs until battery is depleted.
Review wiring:
Hot to timer black.
Neutral to timer white.
Load to timer red.
Ground to timer green.
Lights will blink if timer red and timer white are connected to load together.
Timer will not function if timer black and red wires are reversed. Display will not show.
http://waterheatertimer.org/Woods-timers-and-manuals.html#59028
Aug 07, 2011 | Woods InWall 7 Day Digital Programmable...
Can't get the telxon PTC-610 to take 10 date for yy
check to see what your OS is.Hold down the SP key and ENTER key and turn on unit. If 67
May 10, 2010 | Computers & Internet
I transfered some songs onto the mp3 player. It froze up and won
I can help you with you Coby 610 mp3 player.
Replacing the firmware in your mp3 player should have it working like new again.
Please try these steps to fix your Coby MP-610 MP3 Player.
I hope that helps.
___________________________
Unfreeze Coby 610
Apr 01, 2010 | Coby MP-610 MP3 Player
unfortunatly this is software driven, who is your software provider? they can walk you through this, if not you can contact us we do have tcal programmers at our location
Kim Ganoe
800-933-2839
Mar 17, 2010 | Computers & Internet
MP3 player seems to be frozen. How do I reset it?
Replacing the firmware on your Coby MP-610 should fix it. Please try these steps to fix your Coby MP-610 MP3 Player.
Feb 25, 2010 | Coby MP-610 MP3 Player
I have a telxon ptc-610 and a new symbol LS2208 and can't get it to scan? Do I need to program?
Hello swschmidt. You are spot-on! You need to do a wee bit of configuration. I host he LS2208 manual on my company site for my clients (www.shiftintoblue.com/resources/ls2208_manual.pdf). Head to page 146: "Wand Emulation Host Parameters". Print that page and scan the 'Symbol PTC Terminal (Telxon)' barcode and you'll be all set. I hope this helped. Good luck!
Jan 08, 2010 | Motorola Computers & Internet
TELXON 610 locked up
Can you turn unit on and off. If so check eprom, it might be in the wrong way. Also do a reset, hold down the 5 key for 3 beeps when unit dispays 67>. This will test memory and reload software.
Jul 13, 2009 | Symbol Telxon PN: FlatRepair-PTC960X-LVL2...
I have a Telxon 610 that is stuck on a screen. I
You can reset it by
What screen is it stuck at is it "6x>"
Apr 24, 2009 | Symbol Telxon PN: FlatRepair-PTC960X-LVL2...
Cannot phone Canada
I had the same problem.
The way around this is to dial the number with one of the following codes in front of it:
*67 or *82
Dialing *67+1+(Canadian Phone Number) <SEND> will make the call to Canada, however, your number will not display on the caller's Caller ID display.
Dialing *82+1+(Canadian Phone Number) <SEND> will make the call to Canada, AND your number WILL show up on the caller's Caller ID Display.
I tried it with my Motorola W375 and it works like a charm as of February 13th, 2009.
Dec 08, 2008 | Motorola Mobility W375 Cellular Phone
Ptc-701
Try these steps to correct the problem...
  1. Turn the Telxon off
  2. Hold down <space>, <enter>, and turn the Telxon on
  3. 42> will display
  4. Hold the 5 key down for three beeps. The unit will go blank for about one minute.
  5. Display will read "MEM OK"
  6. Turn the Telxon off and wait about one minute
  7. Turn the Telxon back on
  8. 42> will display again
  9. Press the 6 key on the Telxon
  10. "TP_" will display
  11. Press 58 and then <enter>
  12. Hold the 3 key down for three beeps
Aug 12, 2008 | Symbol PTC 701 Portable Terminal
Computers & Internet Logo
868 people viewed this question
Top Symbol Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Greg Cann
Greg Cann
pkwc
Are you a Symbol Computer and Internet Expert? Answer questions, earn points and help others
