Question about Sewing Machines
Brother xl-3022 sewing machine
My sewing machine will not sew zig zag stitches or any of the other sititches aviable on it because it seems to not be picking up the bobbin thread all the time the needle moves to the right positions for the stitches but does not produce the correct stitch I have changed needles, rethreaded, checked bobbin and no good results. I don't know anything about how to check the timing but think this may be a factor any help would be greatly appreciated. I have a XL-3010 & it will not Zig-Zag or any side stitch.It will go side to side but will not pick up the right side of stitch.HELP!!
  • deadlydan Aug 29, 2008
    cant draw up the bobbin thread
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
Posted on Aug 16, 2009
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 87 Answers
SOURCE: my zig zag stitch is distorted on the top side but
The bobbin tension sounds too loose. This will help if you have a bobbin case and not a drop in bobbin. Let me know if you have a drop in bobbin:
Setting bobbin case tension:
Put wound bobbin in bobbin case. Thread it in case. Hold the thread and carefully let go of the case only holding bobbin thread. The case should NOT move. Quickly let your hand drop 2-3 inches to let the bobbin case free fall for 2-3 inches, the bobbin case should move slightly then stop. It moves because it let’s a little thread off the bobbin. It should then stop .5"- 2" of thread should release. If so, your bobbin case tension is right. If it’s right then begin to look at your top thread tension. Always Always start with a properly adjusted bobbin case, then adjust your top tension accordingly.
Posted on Mar 19, 2009
SOURCE: Zig Zag Stitch not working
THis problem occurred as I was sewing on Neoprene. I was using Gutterman all-purpose thread and a size 80 needle. Tried switching to a size 70, then to size 90. Still unable to zig zag. After inserting a test sample of cotton, the zig zag worked perfectly, so I knew it was not a mecahnical problem. I switched needles again. This time to size 90 for stretch fabric. Voila! Problem solved.
Posted on May 24, 2009
  • 8 Answers
SOURCE: Singer Athena 2000 won't zig zag
Try pushing the reset button underneath the machine. Mine does that too. I had it repaired a few months ago...apparently it needs a circuit board that is no longer available.
Posted on Aug 01, 2009
How to Change the needle position in XL2600i brother sewing machine?
The manual should be helpful:
Brother XL 2600 Operation Manual
FWIW, not all machines have a needle "position" function even though they can make a zig-zag stitch. The home position is the center and the zig-zag selector just sets how wide the stitch will be.
Dec 08, 2016 | Brother Sewing Machine - XL2600i
Machine not picking up a zig zag stitch
it's possible that the cam that makes the zigzag stitch could be worn or damaged, it would probably be a good idea to have the machine checked.
Feb 23, 2014 | Brother XL-5700 Mechanical Sewing Machine
What are the settings for regular sewing, I do not have a manual. It has 3 knobs on the front and 1 on top? This might have something to do with my problems.
The three front dials are as follows....left to right-Stitch width, type of stitch, and stitch length. The dial on the top adjust the top tension.
For straight stitch you want 0 stitch width, straight stitch, 3 for stitch length.
For zig zag you want turn your stitch width to how wide you want the zig zag, choose zig zag stitch, and choose how close you want the stitches to be on the stitch length dial. Practice on a piece of fabric. Usually for zig zag you will want to loosen your top tension a little bit.
Aug 11, 2009 | Brother XL-5130 Mechanical Sewing Machine
Brother XL 3030 i can't seem to get it out of the zig zag stitch mode. Help
it is easy to switch the stich modes
there are two wheels on the side on the mchine
one in for manualy stiching *the big one)
and the little one changes the stitch
you have to look at the LCD screen to make sure the numbers correspond
Feb 17, 2009 | Brother XL-3030 Electronic Sewing Machine
Suddenly zig zag stitch not working?
Because it is almost a straight stitch but the needle continues to move in a zig zag fashion is reason to believe it is in a long stitch. By changing the number of stitches per inch there will be a very noticeable looking zig zag stitch.
Mar 25, 2017 | Brother XL-2610
Sewing Machines Logo
572 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
