Question about Microsoft Windows Server 2003 Enterprise Edition x64 for PC
PXE booting errors
I am trying to boot computers to my pxe server for imaging. The error messages I am getting are:
PXE-T05: Unknown Transfer ID
PXE-E36: Error Received from TFTP Server
And then it stops the network boot connection.
I am running symantec ghost solution suite 2.5 and am running into errors when I boot a client machine to the network. I have configured the DHCP server options 66 & 67.
Option 66: 172.20.1.12 (PXE server)
Option 67: C:\PXE Server\TFTPRoot\Boot\GhostNBF.vfd (Bootfile name and path)
The PXE server is a Windows XP Pro workstation and the DHCP server is Windows server 2003. They are on two seperate machines.
Do I need to configure option 60 on my DHCP server? Is there some other issue that I may not be seeing? I have tried to google it but have come up empty. Any help is appreciated and thanks in advance.
  • peterwhacker Jul 13, 2009
    I fixed the issue. I had the settings correct. I just change the static IP address of the PXE server (XP Pro Workstation) and never rebooted the machine. Once I rebooted everything worked.
  • 339 Answers
I don't have any experience with this product but I am 99.9% sure your problem is with Option 67. This path is from the root as defined for the TFTP server, i.e. root for the TFTP service is not the same as root for the server proper.
Most likely it should be something like:
\Boot\GhostNBF.vfd
Posted on Jul 13, 2009
ERROR : F3-F100-0003 when running recovery disc for Toshiba Satillite L755-25217
Just format your Laptop because your operating system is damage.Install another Operating System that's all.
Mar 26, 2013 | Computers & Internet
Aspire 5315
If your computer is working fine then, disable PXE boot in BIOS or remove from 1st boot option. This is a LAN (network) boot option. It can't find a DHCP server, and is usually used to load an OS image. That's why is says check cable.
For the most part not a real problem. More of a warning.
Sep 26, 2012 | Acer Aspire 3680 Laptop
System restore disc 1 erased & overwrote hard drive. Second disc won't start. All i get is a lengthy paragraph that boils down to : MEDIA TEST FAILURE, CHECK CABLE. PXE M0F: EXITING PXE ROM.\r\n ...
Your computer is using the network-connection to try to connect a "network boot server", to try to load a bootable image across the network.
The 'MEDIA TEST FAILURE, CHECK CABLE' is the error-message when no "network boot server" responds to a "network boot request".
The 'EXITING PXE ROM' message is the exit from the P(re) (e)X(ecution) E(nvironment) part of the R(ead) O(nly) M(emory) inside your computer, since the "network boot" did not proceed.
So, insert "Restore Disk #1" and restart your computer, and FORCE it to "boot" from the CD-ROM device -- not from the disk-drive. When prompted, insert "Restore Disk #2" to continue the reinstallation of Windows. When prompted, remove the disk from the CD-ROM device, and restart your computer.
Note that it's also possible that your disk-drive is "dying" -- any attempts to install Windows on it have FAILED. Thus, any time to "boot" from those "not-written" files will cause problems.
Dec 28, 2010 | Toshiba Satellite P205D-S8804 Laptop
Can't boot up without a boot disk
Your computer has been configured to try to "boot" by loading the Operating System from a network-connected "boot-server". Since you're _NOT_ likely to have such a "boot-server" in your home-network, the error-messages that you get are what are _expected_ when your computer is _NOT_ connected via the Ethernet cable to a 'PXE' (Pre-Boot Execution Environment) boot-server.
Enter BIOS-setup, and disable the "boot from network" option.
Mar 01, 2010 | Computers & Internet
My tosiba a70-kl1 starts up with a black screen and error messages stating "PXE-E61: Media tes failure, check cable" and "PXE-M0F: Eiting PXE rom"
You haved enabled the capability for your computer to "boot" itself by reading from a boot-server connected to your network-cable.
But, the network-cable is unplugged, resulting in the "check cable" message.
What this _could_ mean is that the computer primarily tried, and failed, to boot from your disk-drive, and secondarily tried, and failed, to boot from your CD-ROM, and so it made a tertiary triy, which failed, to boot from the "network", i.e., that your hard-drive is not functioning.
Reboot, and enter "BIOS setup", and disable the "boot from network" option, to get rid of those error-messages. But, it's still possible that your disk-drive is malfunctioning.
Sep 14, 2009 | Toshiba Satellite A70 Notebook
Upon booting I get this error. for realtek
PXE means Pre-Boot Execution Environment. You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error.
You have to replace the hard drive and reinstall the operating system?
Jul 09, 2009 | Toshiba Satellite P205-S747 PC Notebook
When turning my laptop on i get a message media test failure
You see this message when the laptop trying to boot from a remote server using the network card. If you didn’t see the PXE-E61 message before, it means that the network card was listed after the hard drive in the boot order (you can set the order in BIOS) and the laptop booted directly from the hard drive. Now, when the hard drive has failed, the laptop cannot detect it and tries to boot from the next available device – the network card. Your laptop is not configured to boot from a remote server using the network card, that’s why you are getting PXE-E61 Media test failure error. You have to replace the hard drive and reinstall the operating system.
Jan 19, 2009 | Dell Inspiron 1501 Laptop
Error message on my broadcom
PXE errors (Also known as Pixie errors) occurs when the system bios setup is configured to attempt to boot to the network card (an option used in some networks to load system images)
You can boot to the system setup (F2 at Dell screen) and make sure the HDD is 1st in the boot sequence and *** if there is a setting for the network card to turn off PXE (Usually they the following options (ON, OFF, ON W/PXE, select the ON option)
If the system is failing to boot to the hard drive at all, this can be a sympton of a failing hard disk drive. You can try and confirm this by booting to the HDD diagnostic on the F12 on time boot menu or boot to the Dell Resource CD and run diags from it. If the HDD fails diagnostics, it definitely needs to be replaced. If the diags pass, it is no guarantee that the drive is good though, just an indication that no fault was found.
Dec 05, 2008 | Dell Inspiron 1501 Notebook
Aspire 5100 how do i run recovery cd's. notebook won't boot up
hi LWeller1l what you computer is trying to do is boot from a network and it's not picking one up so it gives you an error message, to check if it's just this....... go into your bios and check the boot order it should have ......cd/rom or dvd/rom drive as first boot option then the .........hd meaning harddisk then the pxe boot, if they in this in this order and the pxe option is not above the harddisk in the order you may have harddisk problem. when the computer boots it uses this order to start, so in this order it checks the cd/rom or dvd/rom for a bootable disk, if none is in there it then tries to boot off the harddisk, if this fails then look to the pxe boot option which is network boot option off a server,........another thing is you if you don't have server you can disable the pxe boot option completly in here........so if they are in this order in the bios then you may have to re-install the operating system or the disk may be corrupted or failed.
Oct 08, 2008 | Acer Aspire 5100 Notebook
Power or boot failure
PXE is a common term when a computer is trying to do what is called a network boot. you probably have a bad hard drive and the computer sees there is no harddrive and is trying to boot from a pxe server off of a network.
Jul 28, 2008 | Acer Aspire 5100 Notebook
Microsoft Windows Server 2003 Enterprise Edition x64 for PC Logo
1,760 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
