Question about Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher
Bosch Dishwasher The label is damaged, but it looks like I have M/N: SHV4303UC Bosch dishwasher. I need to reset (reboot) the electronics. It is stuck in the opening cycle of draining excess water. I've tried turning of the circuit breaker for a long time (10 hours overnight) and that did not work. How can I correct this?
  • Anonymous Mar 30, 2014
    Our bosch is not draining looks like the pump is clog, how would we go about fixing it ourselves?
  • 76 Answers
The reason it is doing this is because the anti flood valve is either stuck or you have a leak in the bottom of the dishwasher. if you tip it back slightly does water come out? if so you have a leak, If not take the front panel of and you will see a round polistorin disc, make sure this is not jammed etc, make sure you unplug machine first.
Posted on Nov 18, 2007
How can I reset our dishwasher
Open the dishwasher door sufficiently to see the control buttons, then hold the two buttons with labels "Cancel Drain" and press for 3 seconds.
Close the door. Wait nearly 1 minute for the dishwasher to complete the cycle.
Open the door and hold the "ON/OFF" toggle.
Reset Bosch Ascenta Dishwashers
Shut off the child lock if needed by pressing and holding "Open the door far enough to see the keys, then hold the "START RESET" toggle until the "ACTIVE" LED become extinguished. On the SHE5AM model of Bosch Dishwashers, hold the "START RESET" key until the display clock shows "0:01".
Close the door and rest about 60 seconds. On the SHE5AM, wait until the display clock displays "0:00".
Apr 06, 2016 | Bosch SHE4AP06UC Dishwasher
Need to replace drain hose on bosch dishwasher model shv4303UC/11
Hi, Welocome to Fixya. You just need to remove the small plastic holding tab at the back where the hose exits the machine. Then along the left side ( from the front...right side from back ) remove the side panel and the hose will simply pull out of place. Hope that answer's your question, let me know how you make out. Thanks for visiting "fixya" today. Please take a moment to leave a comment and also rate the solution provided accordingly. Good luck. Macmarkus :)
May 29, 2010 | Bosch 24 in. SHV4303 Built-in Dishwasher
My dishwasher is stuck on the "clean" cycle. I've powered it off hoping to reset it but that didn't work.... HELP!
Go to the fuse panel and swicth off the breaker labeled dishwasher. leave it off for about 30 seconds to a minute. This will reset the electronics in the dishwasher. It should work after that.
May 20, 2010 | Kenmore 24 in. 15252 / 15254 / 15259...
Try turning the dishwasher off at the breaker. Leave off for about 15 minuites and turn back on again. This will sometimes reset the electronics.
Dec 29, 2009 | Bosch Dishwashers
Bosch SHY56A05 Dishwasher was running even with door open
find out first from boschwhats covered and whats not. i think bosch has a 2year iw on electrionics, and some models has a recall, go to thermador .com and you will be able toget the # to bosch which is the same company and give them your model # and serial # they will tell you whats is covered and whats not.
Jul 29, 2009 | Bosch 24 in. SHY56A05 Stainless Steel...
Dishwasher finis tone
  • Open door, push and hold Delicate/Econo button, then turn the dishwasher on while holding Delicate/Econo button.
  • Release Delicate/Econo button.
  • If module beeps, then end of cycle tone is on. PressDelicate/Econo button to disable tone.
  • If module doesn’t beep after button is pressed, then tone is disabled.
  • Turn off dishwasher to save selection.
Jan 27, 2009 | Bosch 24 in. SHU43 Built-in Dishwasher
Bosch Dishwasher SHV4303UC - Does not drain.
Try looking for slithers of glass etc under the impeller. Remove the sump covers (filters) and look into the bottom. There will probably be a small cover held down by a screw. Under this is the impeller. Roll up a hand towel into a cigarette shape and slide this under the impeller - that should clear anything out.
Jan 20, 2008 | Dishwashers
Bosch 24 in. SHU66C02 / SHU66C06 Built-in Dishwasher Logo
563 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
