Back to:
Tags:
Neovo SX-19A  19
NO PICTURE
posted by daffid on Nov 16, 2007
I have a flashing green light on the PSU when plugged into the monitor [sx-19a] when i unpluged it the light goes solid, the light on the MON is a faint yellow when powered up.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Nov 16, 2007
Not Rated (0)
ntg1976
Rank:Guru Guru
Rating: 88%, 108 votes
Bad power supply. The light is green when it is not plugged into the monitor because there is no load on the power supply. When you plug it in the monitor tries to draw current, nothing the PSU can handle now, so the light blinks. The PSU can not provide the amps that the monitor needs.
Get a new power supply, you can find them on ebay. Just make sure the voltage and amps match. It is ok to buy a power supply with a higher amp rating, the monitor will only take what it needs. Also make sure the power plug that plugs into your monitor matches.
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on NO PICTURE:
I don't want to Accept this solution
Can you Help with these Monitors problems?
Monitors
Screen flickers and flashes. Then settles down for a few...
Monitors
hi dear, my computer works fine but...
Monitors
i have done this before connected me laptop to my moniter...
Monitors
Bro from where are you? got the same problem but finally...
Monitors
I have cracked my 19" HP monitor (works fine still)...
Loading problems.
Repair Service
Find Monitor Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
