Question about Dell 1815dn All-In-One Laser Printer
MFP 1815 D Unlock Scanner message
Printer type = Dell Laser MFP 1815D
Problem = When turned on printer makes loud noise and displays message 'unlock scanner
Inside the print tray (where the paper comes out) on the upper right there is a blue lever. Pull it toward you and that will unlock the scanner. I just did this and restarted my printer and it worked! Hope this helps!
Posted on Aug 04, 2009
How do I fix an unlock scanner error?
I work for Dell's Social Media Team and would like to you help with your question.
Please turn off printer. Unplug the power cable.
Inside the printer output tray (under the scanner), there should be a blue slide switch on the underside of the scanner housing. The blue button is on the underside of the section where the printed papers would emerge. This is the scanner unlock switch.
If issue persists, please contact our printer support at 1-877-335-5767 for further assistance.
Pradeep Lokesh
Social Media and Community Professional
Order Status: http://del.ly/61822hij
Download Drivers: http://del.ly/61832hid
Jun 03, 2015 | Dell Mfp 1600n All-in-one Laser Printer
Message Dell 1815 unlock scanner - how do I unlock
There's a little blue toggle switch where the copies/scans come out from. Pull the blue switch toward you, turn off the printer, wait a few seconds, and turn the printer back on.
Aug 04, 2014 | Dell 1815dn All-In-One Laser Printer
My scanner won't copy, all I get are black lines
Something could be electrical/mechanical mistimed now in a mechanical way dirty microswitches that have not give a break on the right moment to stop the scanner and has damaged something what has to made the loud noise .
Keep in mind your safety by working on high voltages and also mechanical recovery.
http://www.refurbisheddellprinters.com/content/manuals/service/Dell%201815dn%20Service%20Manual.pdf
Aug 11, 2017 | Dell 1815dn All-In-One Laser Printer
How do I unlock the scanner on a dell laser MFP 1815 dn printer. I can't fax or copy anything. It says the scanner is locked.
Aug 27, 2010 | Dell Printers:Dell MFP Laser Printer...
Dell a940 AIO makes noise as soon as i turn it on then displays unlock scanner - tried to but will not unlock
Found this: http://support.dell.com/support/edocs/systems/a940/a940en1.pdf
Page iv identifies the location of the scanner lock
Page 44 contains the following
• You unlock the scanner bed. For help locating the scanner lock, see the picture of the printer on page iv.
Page 51 contains
The scanner is locked. To unlock it:
1 Press Power to turn the printer off.
2 Use both hands to lift the printer (scanner unit) until the scanner support
holds it open.
To the left and beside the scanner support is the scanner lock. For help, see
page iv.
3 Pull the scanner lock toward you to unlock the scanner.
4 Using both hands, lift the printer (scanner unit).
5 Push and hold the scanner support back.
6 Lower the printer (scanner unit) until it is completely closed.
7 Press Power to turn the printer back on.
Hope it helps.
Oct 25, 2009 | Dell A940 All-In-One InkJet Printer
Dell laser mfp 1815 dn "scanner locked" message
When you lift the scanner lid look to the left bottom. you should see a green slider button. If you stick your hand in the output tray and get it rigth under the green slider you will find a lever. Move that thing backwards or forwards, that is your unlocker.
Jul 06, 2009 | Dell 1815dn All-In-One Laser Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Dell 1815dn all-in-one-laser
There is a little tab that locks the scanner bar.
Open the flatbed cover, and you'll see it in the left corner closest to you.
To unlock it, reach your hand (palm up) into the area the the paper comes out in.
Slide the tab to the unlock position (you'll be able to see it through the flatbed area.
If you need a complete manual for the MFP, you can go to the Dell website, in the support area, and download a copy of it.
Aug 11, 2008 | Dell 1815dn All-In-One Laser Printer
DELL PRINTER 1815
I've had this same problem, and so far the only way to clear it has been to turn the machine off and on.
Mar 02, 2008 | Dell 1600n All-In-One Laser Printer
Dell 1815dn All-In-One Laser Printer Logo
798 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
