Question about Microwave Ovens
I've the heat elelements of a 7093S Toastmaster convection oven burned Up. I need you tell me the mail adrees where i can put a order. Or, you send me the goods. Thsnks
  • tosaju66 Jul 14, 2009
    OK:
    None of the suppliers posted, deals with 7093S models. What I want is to know the mail adress of whom I can ask the heat elements. I even don't know the part number of that elements. Am I clear ? (I am not an English speeking person). Thanks
  • Microwave Ovens Master
  • 19,396 Answers
Give a call to one of the sellers below to get the replacement part, if they do not ship to your area let me know:
Toastmaster Parts
Toastsmaster small appliance parts,Toastmaster toasters
Posted on Jul 13, 2009
My Panasonic microwave convection oven the convection oven is not heating up
~ Please e-mail me directly with your FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
~ William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Feb 20, 2017 | Panasonic Microwave Ovens
7 yr old unit emitting burning smell. Everything still works. Is it worth trying to get repaired or just buy a new one.
is the burning smell just when you use the convection oven or when you use the microwave , reason I ask is that if its only coming from the convection oven then chances are you have something melted on the heat elements , this can be cleaned off with a dry brillo pad
Nov 20, 2015 | GE JVM1790 Convection / Microwave Oven
I need the manual of my haas microwave oven HMW 43 W I want to know can i bake in my oven or not
m/w do not bake they heat up water molecules in the items that you put in them . unless it is a m/w, convection oven that has a heating element and a convection fan in addition to m/w components in it usually a metal fan visible protruding from back of inside the cavity. also m/w , convection ovens are ether over the range or together with convection oven in the wall combos and cost quite a bit more then counter top. $250 +
Jan 22, 2015 | In Microwave Ovens
My GE Profile JVM1790 convection microwave has issue. Was using the convection portion when a small spark and flame appeared and then went out and soot and smoke was all inside and now will not heat up...
Yep, that sounds very much like the heating element burned out. It happens. You should be able to get a replacement from the manufacturer's website... or there may be a list of repair centers in the manual - pick one & try to order the heating element through them.
Aug 13, 2014 | GE JVM1790 Convection / Microwave Oven
Microwave won't heat for first minute - starts working normally after that.
The magnetron may be defective. You can replace the magnetron, there is no other possibility.
Jan 16, 2013 | KitchenAid KHMC1857WSS Microwave Oven
Sharp convection microwave oven model R1875F. It's cooking on the left side faster then the rest of the oven. It seems to burn on the left side and not cook in the middle.
see the next causes. God bless you
Diode The high voltage diode converts the A/C power output of the transformer to D/C, doubling the voltage to nearly 5,000 volts. This high voltage powers the magnetron which emits the energy that cooks the food. If the diode burns out, a lower A/C voltage reaches the magnetron, which is not sufficient to power the magnetron. When the diode fails it is often visibly burned out. If it appears to be good, it can be tested with a volt-Ohm meter capable of testing diodes. High voltage diodes frequently fail and are one of the most common points of failure in a microwave oven.
Door Switch If the microwave does not heat, one of the door switches might be defective. Microwave ovens normally have three door switches, if any of them fail the microwave does not turn on and does not heat. Check the switches for continuity with an Ohm meter.
Magnetron If the microwave oven doesn't heat the magnetron tube might have burned out. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. If the microwave oven is turned on when it is empty this can cause the magnetron to burn out. Once it is burned out it has to be replaced, it's not repairable.
High Voltage Capacitor If the microwave doesn't heat the high voltage capacitor might be defective. The high voltage capacitor works with the high voltage diode to convert the output of the transformer to DC voltage and to double the output voltage. If the capacitor is burned out the entire high voltage circuit stops working properly. The high voltage capacitor can be checked with a special VOM meter which has a capacitance testing capability. Be aware that the high voltage capacitor can retain a charge of more than 3,000 volts and can injure or kill a person if not handled properly. Only trained technicians should perform this type of testing.
High Voltage Transformer If the microwave does not heat, the high voltage transformer might be burned out. Microwave ovens produce a very high voltage in order to power the magnetron antenna, which emits the energy that cooks the food.
Thermal Fuse If the microwave doesn't heat the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
Thermoprotector If the microwave doesn't heat the thermoprotector may have tripped. This is a safety device to prevent the microwave from overheating. It can be tested for continuity to see if it's blown.
Main Control Board If the microwave doesn't heat the main control board may be defective. This is not common. When a microwave doesn't heat the problem is usually within the high voltage circuit; either the high voltage capacitor, diode, transformer or magnetron.
Oct 03, 2012 | Sharp R-1870 Convection/Microwave Oven
I have a sharp over the range convection microwave modelr-1874F The convection works but the microwave sounds like it working, the turntable turns but it does not heat the food we tried unplugging it for...
Every time the microwave part of an oven do not heat it normaly means a faulty MAGNETRON (the device that produces microwves) unfortunately if it's the magnetron they are allmost as expensive as the oven it self, you could allways check for a burned fuse, (allways be prudent opening an applyance)
Jan 04, 2011 | Sharp R-1874 Convection/Microwave Oven
Our dgs61st DeLonghi gas oven was installed on Wed. 3rd Nov. We gave it the recommended 'burn off', today we have put a chicken in and started cooking it on heat 140/155, after 20 minutes the oven is...
Could it perhaps be the chicken fat burning?
I take it you are using convection only and not microwave power because if you use microwave power and do not contain the fat in with the chicken, the fat will be heated to its flash point by the microwaves and smoke heavilly.
Hope this explained it for you.
Nov 07, 2010 | Microwave Ovens
Will not heat on one touch mode but will heat on convection made
your microwave magnetron part is probably broken you need to send this to a shop im afraid, might cost you 40- 60 $
cheers
Nov 25, 2008 | Viking VMOR205SS Microwave Oven
I NEED A MANUAL FOR A OVEN. MODEL # R9H81, SERIAL 3 16010 SHARP CAROUSEL 11, MICROWAVE CONVECTION OVEN. INSTRUCTIONS NEEDED, HELP !!
I was looking for a manual for the oven, finally found someone to talk to from Sharp Co.
He did not have a manual but had me try some of the buttons on the front of the oven.
Some, in fact most, of them do not work. It was the convection part of the oven that I wanted to use because I am alone and do not always want to heat the oven for just one small something.
I am afraid it has been stored too long and would cost more to have it fixed.
Thanks for the e-mail.
Jane Josselyn
Jul 31, 2008 | Sharp Microwave Ovens
Microwave Ovens Logo
27 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
