Question about Canon BubbleJet i560 InkJet Printer
DISPLAYS PRINTER TANK FULL BUT DOES IT HAVE A TANK?
    President:
  • 2,306 Answers
It does have ink absorber pads on the bottom of the printer. When they are full you need a shop repair to replace them and reset the error code.
Posted on Jul 13, 2009
A window displays inktank full and the printing is cancelled, when i give the print command ? what sould i do? when showed to an expert ,he told i need to update the firmware. Is this the solution ,if yes...
I suggest a window display "Waste Ink Absorber Full" or "Ink Tank Absorber Full" . It has to be reset.
4 step to Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
If that not work just write on kernel84@abv.bg , and i send you a software to reset your printer.
Jan 18, 2011 | Canon PIXMA iP1000
I keep cleaning the toner/printer waste tank cartridge and the printer continues to stop printing and the same error message displays saying "Replace/Install waste toner printer cartridge.
How are you cleaning the tank? Just dumping the contents into a trashcan may not work. The printer uses a light sensor to detect whether the tank is full. When the light does not shine through the clear window of the tank, the printer thinks that the tank is full. Sometimes cleaning the window with a cotton swab will make it work, but it can be difficult since the location of the window with respect to the opening of the tank is not a straight shot.
Another way to clean it would be dump the waste toner into ther trashcan. Tap the tank a few time to get as much of the toner out. Then add some soap and water into the tank and seal the tank opening with the green lid. Then shake the soapy water in the tank for a about a minute. Then dump the soapy toner/water out. Rinse again with just water and and allow it to dry. You don't have to get the tank completely clean, just enough to stop the waste tank error message.
Hope this helps.
Nov 17, 2010 | Samsung CLX 3160fn All-In-One Printer
I replaced the clear ink tank on mx7600 and the message "the clear ink is empty" will not go away nor will it print in black. The brand new Canon brand clear ink can be seen on the ink tank itself and in...
Yeah, me too. I fiddled with cycling the power, removing and reinserting the tank, doing maintenance tasks like cleaning the jets, yadda, yadda, no dice. New full Canon tank displays empty. Boo.
I figured "What the heck, I'll try printing anyway" and sent a test page on plain paper. It warned me the tank was empty, then did a bunch of those cartridge moves it likes to do (you hear the carriage moving around cleaning or something). After like 90? seconds of cleaning noises, it figured out that the tank was full, the status went to full, and it printed the page fine.
So my advice is, try printing a page anyway.
Oct 20, 2010 | Canon PIXMA MX7600 Multifunction inkjet
When I turn my printer on it starts the warm up process then 1 second later stops abruptly and displays a red light.
Please check the Toner waste tank, and clean it. The red light indicates that the printer's toner waste tank is full. Good luck. thanks for using FixYa.
Jun 10, 2010 | Samsung CLP 300 Laser Printer
Tank absorber full and lights blinking
The POWER Lamp Flashes Orange Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact a Canon service representative.
Note
Canon recommends that you call for service as soon as this error occurs. Once the waste ink tank becomes completely full, printing will no longer be possible.
Sep 14, 2009 | Canon i350 InkJet Printer
Fuel gauge inaccurate
Change the fuel gage sender unit in tank.its faulty.
May 30, 2009 | 2001 Jaguar S-Type
EPSON STYLUS C43SX PRINTER
You need to reset the waste tank or the counter to resolve the problem.
If your C42 blinks both lights and displays a message to the effect that parts inside your printer have reached the end of their servicable life, then you probably need to clean the waste ink pads. These pads collect waste ink whenever the printer cleans it's heads. The printer counts how much ink it thinks is in the waste ink pads and refuses to print when they are full.
To verify whether this is the case, download the "SSC Service Utility" from http://www.ssclg.com/epsone.shtml.
http://www.ianwillis.co.uk/c42/
Mar 26, 2008 | Epson Stylus C43SX InkJet Printer
HP office jet 7310
Please goto the HP website and see if there is a firmware update for this machine. Download and you can also download the procedure.
It seems to be that it's a controller issue and reinstalling the firmware will usually resolve the problem.
Hope can be some help
J
Dec 11, 2007 | HP OfficeJet 7310 All-In-One InkJet...
Cartridge Problem
Go to Printer and faxes right click your printer and go to Properties and maintanence,. Threre you will find reset ink cartridge do that it should solve your problem.
Nov 01, 2007 | Canon iPF700 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
88 people viewed this question
old marine
old marine
