It looks rather like my slow cooker which has a 3 position switch with LOW, HIGH and AUTO.
AUTO uses a thermostat control to prevent the contents from boiling. Useful if being left unwatched. HIGH setting can cause burning if contents not stirred, and LOW setting is only of use to keep things warm. Hope that helped.
Hi, well, Auto means that it uses an internal, weight & temperature sensor to determine the Cooking time of whatever is in it. It will then "Cook" until "It" thinks it is "Done" and turn off at the end.
I believe that they are NOT that accurate? But a possible time saver nevertheless.
The auto button is ususally it startts off on high setting to warm up the crock and when it reaches a pre set temperature it will shift to med or low which ever is the next lower setting it will continue cooking at this setting unless you change it
