Question about Refrigerators
Fridge was warm then would not restart after stopped, it was warm on getting up this morning but still running s adjusted door as seal semed off , it was still running, turned to off then back too six but would not restart any ideas or is it dead
  • 53 Answers
Your compressor unit might have failed and need replacement.
In case it is running and no cooling could be refrigerant leak and require recharging of the refrigerant.
Also ensure that the thermostat and the relay are in working condition before touching the compressor.
If it is an old unit you could think about replacing the same and enjoy the latest technology and lesser power bill.
Posted on Jul 13, 2009
Samsung refrigerator model RB1855VQ has ice build up in the fridge underneath the drawers. How can this be fixed?
By defrosting it. Refrain from adding warm items to the fridge. Make sure the door seal is intact and sealing well. You can also raise the temperature a little. It should be 4'C first thing in the morning. Use a good quality fridge thermometer.
Sep 25, 2017 | Samsung Refrigerators
My Defy Fridge is Running Non Stop , Please Advice
When you open the door, check the door seal. If it is hot then it means your door seal isn't working properly. This will be allowing warm air to enter the fridge and cause the motor to run constantly and 'burn out'.
Check for the part in your manual or go online.
Mar 16, 2017 | Refrigerators
Door not creating suction when door closes
the door may need adjusting
cut an place a strip of paper between the seal and the fridge and close the door
if the paper pulls out easily then the seal is not touching fridge
The suction is created when the warm air from the room that gets into the fridge when the door is opened is cooled down and occupies less space hence the lower pressure and the vacuum forms
May 12, 2016 | Refrigerators
Fridge not cold. Compress or runs 5/10 seconds smoothly then kick s out . DW
  • Check the thermostat control. Even if you've not touched it, something may have knocked it and adjusted the setting. The thermostat may also need to be adjusted depending on the temperature of its surroundings and the coldness of the weather.
  • Make sure any food stored in the fridge or freezer is not blocking any air vents. This can stop air circulating properly.
  • If the fridge is too close to the wall, the condenser coils will not function properly.
  • Defrost the fridge and freezer thoroughly and clean the inside surfaces with warm water. Check any air vents to ensure they are not blocked.
  • Clean the condenser coils at the back of the fridge using a vacuum cleaner, making sure all dust and any dirt are removed. Clean any stubborn dirt away with warm soapy water, being careful not to scrape the coils. Turn your fridge off and unplug it before doing this.
  • Make sure the fridge's fans are not clogged and are able to function properly. Again, you need to turn your fridge off and uplug it before attempting this.
  • Check the door is closing properly. Make sure nothing is obstructing it or pushing it slightly open. Ensure the seals around the edge are working well.
Jun 02, 2015 | Refrigerators
Freezer is frosting and refrigerator is warm.
As far as your freezer frosting up, sounds like a door seal problem, run your fingers along the seam of the door seal, there should be no splits/holes in the seal.
As far as the refrigerator either there is a secondary fan motor, or there is a obstruction blocking the air movement, if the freezer has a bad seal, its suspect ice is still building up.
Jul 08, 2013 | KitchenAid KSRV22FV Side by Side...
Ice inside my fridge
Check door seal intact and sealing ok, clean rear compressor section of all dust/ dirt/ fluff and check drain hole on rear of fridge.as water should not pool inside but run away outside rear. Lift/ adjust door to make sure it closes properly.
May 17, 2012 | Samsung Refrigerators
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last...
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Jul 13, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Seals are hot
hI iF YOUR FRIDGE AND FREEZER ARE COLD AND TEMP IS OK THEN ITS FINE oN FRIDGES THERESHEATERS THATGO AROUND THE DOOR TO KEEP THE CABINET WARM TO STOP CONDENTION SO THIS IS NORMAL THANKS FOR THE QUESTION THE APPLIANCE DOC
Sep 12, 2008 | Sub-Zero 632 / S
Refrigerators Logo
52 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
