BART Steltz Posted on Oct 24, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
AFTER ALL THE PROBLEMS IVE HAD WITH UNIT SHUTTING OFF , NOW IT WON'T TURN ON NO MATTER HOW LONG I LEAVE IT UNPLUGED ETC.......HEEEEELP!!!!!!NOW WHAT????
Steve K
Level 3:
Genius:
  • Master 1,054 Answers
  • Posted on Oct 24, 2015
Steve K
Master
Level 3:
Genius:
Answers
1054
Questions
0
Helped
573627
Points
2865
What brand/model receiver? Some will lock themselves into protect mode if the protect circuitry is tripped too many times.
Testimonial: "HTR-591 RECIEVER HOW DO I GET PROTECT MODE 'UNLOCKED'?"
What do i do?my heating thermostat won't turn off and house is getting hot!
First determine if in fact the thermo is or is not shutting off. There is usually a little indicator as to when it calls for heat .so how do you know it's the thermostat. What type is it electronic or not. Also what type of heat hot water or forced air etc,need to know etc. if house to hot shut the heat off at your service switch,usually wall switch with a red cover.located on the heating unit or a hallway to basement on wall.
Nov 14, 2012 • Dryers
Got wet and won't turn on
Try this old trick... take out any external things such as battery etc, and put the whole lot under some uncooked rice...
The rice absorbs any water. Leave it there for a few days.
If the circuitry isnt fried, then it could come back to life, ive done it before with phones.
You can also try it with a very VERY low oven heat.. Like 60C,( 140F)
Oven won't bake F-4 signal
God i havent been around i hope you unpluged this unit by now, leave unpluged for a few min's , this will usually fix this problem
2answers
Acer aspire one netbook A0751h-1346.Kept shuyting down even after charging .turn on it would turn off and now there is no power unable to turn on.Is it battery adapter or a driver issue.please help...
Ive seen this problem recently. It was the battery dying. Basically the pc needs a small amount of power from the battery, even when plugged into the mains.
Get a cheap one from ebay, $25.
Tv will not turn on leave unpluged a few days plug
The DM power supply board,probobally have those dying leakages gases about to be dead parts call capacitors.U have tools and know basic soldering?Tries website like Tvrepairworld.com to buy a capacitors kit,to replaced those dying capacitors belong in the DM power supply board.
When i try to open facebook i get redirected to my prepaid recharge site ! . ive tried using firefox etc. but no good ive checked my firewall settings ..no good ..heeeeelp please
I don't know what ISP you are with but it seems like it is the ISP that is redirecting you. I would say that the chances are that you need to add some credit to your account. Nothing you have described indicates a system error on your PC which leads me to conclude that you may have run out of credit.
No audio video
PS3 is The amazing device by sony but it has some common problems like sound , video problem etc.... Good news is that these all problems can be repaired with the help of DIY Guides, one such guide available at PS3 Repair Blog
Dell dj gen 20
it is possible the the battery cable is unpluged
5helpful
2answers
Heat turns off
Sounds like the high limit switch on the heater is kicking off. The flash is the switch shutting off the heating element. The only way to reset it is to turn unit off for about 5 minutes. Possible problems are: 1.) Bad thermostat 2.) blower motor not turning fast enough which means motor is bad.
 Grubhead
Grubhead
SmartAviator
SmartAviator
