Question about OKI MICROLINE 280 Elite Matrix Printer
How do you set up the OKI Microline 280 to print from RS-232?
How do you set up the OKI Microline 280 Elite to print via RS-232?
  • 40 Answers
SOURCE: oki microline 590 elite
What driver are you using for this printer? Try loading a Epson LQ1050 driver and try again.
Dezzi
Posted on Dec 31, 2007
  • 32 Answers
SOURCE: Problem with oki microline 395
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer4.gif.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print4.gif.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints4.gif, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Posted on Feb 15, 2008
SOURCE: Alarm light Microline 320 Turbo 9 pin printer - won't print
We swapped out the printer for another one we had in the office that was working. The new printer also got the alarm light. From that we concluded that it was a bad serial card. We swapped the serial card from another printer, and the original printer started working perfectly. Now we just need to find out where we can purchase another serial card, as we have no more 'spares' around here.
Posted on May 23, 2008
sys_admin
  • 829 Answers
SOURCE: font size
Probably the monitor-chip on the board is working inproperly.
Consult the vendor or manufacuturer.
But before this, you may download new monitor driver from the manufacturer.
Posted on Jan 11, 2009
  • 5 Answers
SOURCE: Oki Microline 590
Try to perform an offline test print using your printer alone
To do this, power off your printer first
Press and hold the LF/FF button on the printer panel then power on. The printer will perform its own printing ( lines of pattern )
If it does it without problems ( no MENU lights came on ) the printer should be OK. If not try replacing the printer main control board.
Hope this helps
KM Hoo
It
Posted on Mar 05, 2009
I have oki microline 320 elite and printer head jams
In my own experience, Okidata printers have a nasty habit of collecting a lot of paper dust. To start out, I would suggest a really good cleaning, with no paper in the machine, with a can of compressed air. If that does not solve your problem, you might have to replace your feed wheel assembly. Hope this helps!
Nov 09, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
OKI ML 280 Elite
You have the Printer emulation set incorrectly. I think it comes as IBM as default and you should try Epson instead. Its a trial and error thing but am sure emulation is incorrect.
Jun 14, 2017 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280 feeds paper continiously after a file print, and won't stop till i pull power cable
First, reinstall the driver and be sure it's the correct driver for this printer. If you drive a word document does it do the same? If not, chanses are the db application is constantly sending form feeds to the printer and the printer will do whatever it's told to do. Try a different printer setup in the db application.
Aug 27, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Oki microline 280
Check printer setup where you define carrige return and line feed options. Alot of times you need to set printer to do an auto CR on reciept of LF or auto LF on reciept of CR. I run into this all the time.
Aug 02, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix... Problem
Be sure when you install new paper that the paper out switch, usually in the paperpath somewhere, is being contacted by the new paper. Usually located on the left side of the paper platten.
Jun 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
Form feed length for 280
change in your computer driver setting
if you using windows xp
click to
start
settings
control panel
printer and fax
select your printer and right click
properties
in general menu
printing preferances
change here paper size
select letter 8.5" 11"
Feb 28, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI 520 ELITE
Kindly check the DPI settings . May be more DPI this time.
Best Regards
Rafique
Feb 19, 2008 | OKI MICROLINE 520 Matrix Printer
EVERY TIME PRINT GET A EXTRA SHEET BLANK PAPER
Printer setup defines different emulator you can use such as IBM Pro/ Brother/Generic. Try a different one that as set now. See if that helps. Does it do the same of printing with a different
application? You may have page length setup wrong in application.
Jan 04, 2008 | OKI MICROLINE 280 Elite Matrix Printer
OKI MICROLINE 280 Elite Matrix Printer Logo
95 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
