Question about Sony Computers & Internet
The vaio turn on but monitor doesnt on - Sony Computers & Internet
    Novelist:
  • 117 Answers
Visit sony esupport site. there have been a lot of known issues like this. if you take a flashlight and shine it on the screen and you can see faintly the text and such, then you have a bad backlight and will need an lcd replacement. if you see nothing and if you plug in an external monitor and see nothing on it, then you run the risk of having a failed gpu on the motherboard. unfortunately i have been seeing this problem too often in the sony vaio series recently
good luck!
ruben
Posted on Jul 13, 2009
SONY VAIO PCG-61813M
I have the same problem, It works at an external display and the lcd and lcd cable work on another laptop.
The problem is that i have a sony vaio and it has no inverter, or at least i dont see one like an hp laptop for example. i tried to switch image from external monitor to lcd and it doesnt work. i tried everything. dont know what to do more, Hope you can help.
I have a Sony Vaio pcg-61813M.
Thanks.
Aug 29, 2012 | Sony VAIO Laptop Intel Core i3 Processor...
I have a light pink Sony Vaio VGN-CR510E and i've had it for a little over two years now. The screen has gone grey/white and will only return to the natural screen when the tops of the screen are squeezed,...
I wouldnt say beyond repair, if you were able to compress it and the screen would appear normal there is a connection problem, your monitor has small connections making it work one happens to be an inverter. It could be that the connection is loose, the bad thing about that is if its loose there is a chance it could cause a short which in return you will need an inverter or whole monitor.
1. try hooking it up to an external monitor, you need a vga or dvi cable and try hooking up to a projector or another monitor, if that doesnt work its your video card. unfortunately either fix is somewhat expensive. Good luck and please vote thank you.
if you have have hooked up an external monitor before here are some instructions
1. make sure the power is off
2. plug the vga cord to your laptop and to the external monitor, 15 pins normally blue or back has 15 little holes ive seen some that are pink.
3. turn both on
4. you may have to hit a function key thats the fn button plus (on mine is f4 small rectangle with a line on each side of it .
5. if the external monitor works then your monitor or the cables to your monitor are bad
6. if the external monitor doesnt work its your video card and you will need a new motherboard if the card is integrated.
Feb 18, 2011 | Sony VAIO VGN-CR510E/L Laptop
Display doesnt work
try to connect an external monitor to your notebook to check if that is not a video card problem, if the external monitor works fine then you have LCD problem.
Jun 10, 2010 | Sony VAIO GRZ610 Notebook
Monitor problem laptop
try setting display settings to default. if that doesnt work, restart and if they are back, you might need a new lcd.
Apr 30, 2010 | Compaq Presario M2000 Notebook
Mylaptop turns on and runs but the screen is completely black. What do I do? The power button is on and the battery charging light is on but the screen doesnt come on at all. I can hear the laptop booting...
Connect an external monitor then power up both the monitor and laptop. If you get display on external monitor, you have 3 possible problem. First, LCD is bad, Second, CFL on your LCD is bad and Third, the cable connecting your motherboard and LCD is bad or the connection is loose. It is better to replace the whole LCD assembly than to repair.
If you have external monitor but still can't get a display, your problem may be on the motherboard.
Apr 13, 2010 | Sony VAIO (PCWA-A200)
I bought a cable that plugs into my laptops monitor outlet and turns the other end into S video and RCA jacks. i Go to my control panel and try to set my tv as a monitor and it makes a couple of buzzing...
there is a piece of hardware that you will need that goes inbetween the laptop and t.v. im not sure what its called but you can call any computer store and they will tell you what it is
Apr 02, 2010 | Sony VAIO PCG-K35 Notebook
Vaio tr1a sreen not working
You need to check if the issue is with the LCD or with the video card. Please try to connect the laptop to a different monitor or another display device. If you get display or any images then you need to get the lcd replaced otherwise its a video card issue.
Jun 20, 2009 | Sony VAIO TR1A Notebook
Sony vaio monitor with internal speakers
There should be an audio cable coming out of Monitor, you'll need to plug that cable in the ouput jack of sound card, turn on/increase the volume of the speakers using the switch, slider present on the monitor and then check. you may also consult the manual that came along with the monitor.
Apr 07, 2009 | Sony Audio Players & Recorders
Sony Vaio Desktop VGC-LS1 Clicking sound, Screen doesnt illuminat
what happen to my PC when i turn on " VGC LS1" got white screen but i still can hear the Windows run normal?? Help Please!! thanks
Mar 10, 2009 | Sony VAIO FX150K Notebook
MY VAIO SCREEN TURNED WHITE
What type of vaio is this?
First attach an external monitor or go to your friends home ,they may have an old crt monitor or lcd,just remove the video cable from their system and plug it into your laptop video port.
when powering-on laptop -press the FN key and the F7 key at the same time to toggle the video signal - video will show on the external monitor or if not you have to replace your LCD.
The above test will verify if the LCD is bad or you have an inverter problem.
Jan 08, 2009 | Sony VAIO VGN-FJ270/B Notebook
Computers & Internet Logo
108 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
