Question about Nokia 2610 Cellular Phone
When i turn on my phone i get a message saying smartchip rejected
When i turn on my phone a message pops up that says smart chip rejected. i cant do anything on my phone unless i take it out. its the one that came with the phone. how do i fix that? will i need a new smart chip? if so, how do i get one?
My Nokia 6085 Phone Says SmartChip Rejected :(
It means your sim card is damaged, so you must renew it
Feb 08, 2014 | Nokia 6085 Cellular Phone
Says smartchip rejected
Hi
remove the sim card from the phone and clean the sim card slot with a cotton wool dabbed in methylated spirit and insert the sim back into the slot,put it on and test it.
If this does not work then you should replace the sim card holder.a repairer can help you with that.
Cheers
Mar 05, 2010 | Nokia 2610 Cellular Phone
It just says smart chip rejected?
Turn off the phone. Take the battery and sim card out. Make sure there is no dust or dirt of where the sim card goes. Blow air (from your mouth) of where the sim card goes. Then place the sim card back in the phone. Make sure it is in the right position. Copper contacts facing downward. Put the battery back in your phone. Turn it on. See if the smartchip rejected goes away.
If not you may need to contact your Phone Provider Tech Support to troubleshoot and confirm that you may need a PUK Code to register or you may need a new SIM Card, as they do fail from time to time.
Jan 14, 2010 | Nokia 2610 Cellular Phone
"Smartchip not provisioned MM # 2" What does this mean???
Your smartchip apparently isn't active with your cellphone service company. Are you certain that the chip you have installed in the phone is the one that your cell service gave you currently? You mentioned putting minutes on your phone, so I'm assuming you have a pre-paid plan. You must have a smartchip that's specifically set up for that type of service.
Nov 14, 2009 | Pantech Matrix Cell Phone
My lg vu says insert smartchip and it's in
Turn your smart chip around. When inserted correct, you will be able to see the slanted corner of the chip.
Sep 21, 2009 | LG Vu CU920 Cellular Phone
Insert smartchip
You are placing the smart chip on top of the smart chip holder. It's a little metal square where the smart chip should go. Lift up the metal square and place the smart chip underneath. I had to go to my local AT&T dealer to figure this out.
Jul 11, 2009 | LG Shine CU720 Cellular Phone
Smart chip
u need to unlocj that phone again.
Sep 21, 2008 | Nokia 6300 Cellular Phone
Insert Smartchip
You have to insert the smart card all the way in on these phones. You can use a pen cap or something to push it all the way in there until it goes all the way in and click and stays there. Then it will not say " insert smart chip" anymore.
Feb 20, 2008 | Sony Ericsson Z525a Cellular Phone
Nokia 2610 Cellular Phone Logo
214 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
