Hi, my tv hc-p4241w was ok but one day, the picture in the screen become wide and then I saw smoke from the rear panel. I switched off the TV, and I found that the C407 have exploded, there's a Diode (RP1H)and a Resistor of 47 Ohms that are open and one big brown capacitor (close to C407 has been affected by the explosion. Can some you help me please? I would Know what's the capacity of C407 and if I can get the schematics for this Tv. I have tested the Horizontal out and it's Ok, other circuits seems ok too. Thanks!
Comments:
Aug 23, 2009
- NO BUT THANKS. I already fix my tv, I replaced the capacitors, the resistor and the diode. I had to calculate the capacitors value but I did it ok and it's working since a month ago.
Thanks.
Look to see if any coolant fluid has leaked from any of the CRT's. This is a common cause of multiple component failures in these models. Look real close at the CRT mounting bracket, the wires coming from the CRT's and look at the particle board below to see if you can see any staining or puffed up wood particles. My experience with the Samsung bds is when you have a multiple compoment failure due to fluid leakage it is best to replace the boards instead of component level repair because other components will fail at a later time. Coolant fluid is real hard to spot since it is ultra clear. Hope this helps.
Was this helpful?
Yes
No
Popular Solutions for Samsung HC-P4241W 42 in. Rear
after changing the SSB that fixed the original problem I found that there is a bow at the top of the...
(More)
after changing the SSB that fixed the original problem I found that there is a bow at the top of the pix and the bottom has black(height problem). i tried to get in to the service mode I could not get to the deflection section. I USED 062596 AND 062597 WHICH PUT me in the service mode but thats it.
Television just turned off so took back off and vacuumed out all of the dust. Seems to be running...
(More)
Television just turned off so took back off and vacuumed out all of the dust. Seems to be running o.k. now, but there are red lines down the middle of the picture and green just to the left of them. Any suggestions. THANKS!!!!
the picture is to big for the screen and the picture is darker than normal and the people and the...
(More)
the picture is to big for the screen and the picture is darker than normal and the people and the colors are in duplicates
no picture just a noise steady when u try to power on and the dvd player below will not work or even...
(More)
no picture just a noise steady when u try to power on and the dvd player below will not work or even eject any help would be appreaicated
