Question about Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator. One month ago the water tap stopped working then I noticied that the top doors to refrigerator would not reliably close like they used to. Last night the temp in the refrig was 70 degrees. Freezer has continued to work and now water tap works. Any solutions?
  • 4,059 Answers
The water could have been frozen in the door and melted when your fridge warmed up.
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it’s wore out and doesn’t work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Posted on Jul 13, 2009
My freezer has started to frost over. It started about 2 weeks ago and is getting worse. What is the cause for the automatic defroster to stop working.
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 15, 2010 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air bottom freezer ice maker not working
I took the arm of the ice-making machine out of the slot and put it back in, pushing it snugly inside the slot, then raised and lowered it several times. Then, with the arm in the up (stop making ice) position, I felt inside the ice-making tray, where I noted there were ice cubes as well as a sheet of ice at the base of the ice-making tray. I poured approximately 24 oz. of hot tap water into the tray to melt the sheet of ice. I turned the freezer temp control to "warmer". I think the freezer temp setting was too cold, causing the ice maker to freeze the water before it could make cubes. I have a working ice maker again!
Cynthia
Sep 07, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Loose freezer door handle
There is a "set screw" on the underside of the posts that connect the handle to the mounting posts on the face of the door of my Jenn-Air bottom freezer. Use an Allen wrench to loosen the set crew, which is very small (my Jenn-Air requires a 3/32" Allen wrench), and then tighten the bolt on the mounting post on the face of the freezer door. Position the handle over the post, then tighten the set screws with the Allen wrench. Cynthia
Jul 21, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
Water dispenser not dispensing
water line or water tank is frozen intermittantly
Jun 30, 2008 | Jenn-Air JFC2089H Bottom Freezer French...
Jenn-Air JFC2089H Bottom Freezer French Door Refrigerator Logo
472 people viewed this question
Top Jenn-Air Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
john h
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
