Question about Garden
Mower starts OK but will run for just a minute then stops - like it runs out of gas
    Problem Solver:
  • 16 Answers
Replace fuel filter an or spark plug
Posted on Jul 14, 2009
Will not run. Spark O.K.,,prime gas runs stops,,
Does it crank with the starter but not start? Need more info.
Aug 01, 2014 | John Deere Garden
Four stoke mower. Mower starts and runs ok but after a short time (10-15 minutes) the engine stops as though it has run out of fuel. Fuel tap on, filter clean, new spark plug. After a few minutes you can...
Your ignition coil is failing when it gets hot.make sure the cooling fins on the flywheel are not plugged up.you will probably have to replace the coil.
Dec 28, 2010 | Briggs & Stratton Garden
What would cause the lawn mower to stop running when not out of gas? If you give it a few seconds and restart it it will run again for awhile then stops. I have noticed if I pump the primer a couple of...
Try using non-ethanol gas. It's death on small engines. Starter fluid gives it a boost if higher octane. Have a reputable repair place clean out the gunk, then use good gas. Best of luck finding non-ethanol. Boating marinas carry it.
Jul 20, 2010 | Mtd 22" Yard Machine Push Mower
Describe your Poulan "" Push
Please change your are filter,or clean it, I hope this helps you and thank you
Sep 10, 2009 | Poulan "" Push Mower
Mower stops running after I've been mowing for about 30 minutes. I changed the spark plug and fuel filter. It seemed to work and I was mowing the lawn then it just started acting like it was running out of...
Mower stops running after mowing about 5 minutes. acting like it was running out of gas unitl eventually stops. I wait 10 minutes and then it restarts, runs good, then erratic...then quits again?
Aug 23, 2009 | Garden
Lawn tractor mower stops running
I have had problems with my mowing equipment. After 15 minutes the mower would die then when cool it would run again. I changed the plug, the gas, the fuel filter,cleaned the air filter, and changed out the magneto coil, none of which fixed it. I removed the fuel solenoid from under the carb and nipped the end off the plunger with snips. That fixed it. The function of the solenoid is to kill the gas when the key is shut off. Near as I can tell the solenoid was going out when hot and working while cool. You cannot just defeat the solenoid by unplugging it because that releases the spring loaded pin and the pin shoves the float up and therefore kills the gas. I had to either spend $50 on a solenoid or nip this problem in the bud. Nipped the plunger and all is well. I posted the solution with photos HERE.
May 15, 2009 | Garden
Possible carburetor problem? Mower runs for
i have a lt 1000 2005 when i start it with cold engine it boggs for a minute then it starts to run smoothly please help me
Apr 19, 2009 | Craftsman Garden
Push mower runs then quits!!
My toro mower starts and will run for ablut 15 minutes and starts to cut out and eventually stop running. What could be the problem
Apr 01, 2009 | Craftsman Garden
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
