Agfa Arcus II Flatbed Scanner
Problem for Agfa Arcus II Flatbed Scanner
How to change lamp in AGFA Arcus 2 flatbed scanner?
By Skippy66 on Nov 16, 2007
I have an AGFA Arcus 2 scanner and the lamp is out, how do I change the lamp? Is it worth changing the lamp as I no longer need that quality scanner/
Robert
Solution #1
posted on Feb 24, 2008
Not Rated)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
http://www.uktsupport.co.uk/scanner/agfa/arcus.htm#a2lamp
  • Turn off the scanner power switch and disconnect the power plug. Wait at least 15 minutes to allow the unit to cool down.
  • Unscrew the two screws at the back of the base.
  • Pull the SCSI board out enough to disconnect the ribbon cable that threads through the opening in the base (on the right).
  • Remove the two screws from the upper portion of the back of the base.
  • Remove the Transparency Option (TPO) from the base.
  • Remove the two screws from the top back of the base. These screws will be visible when the Transparency option is removed.
  • Remove the two screws from the top front of the base and lift the plastic housing off the scanner.
  • Move the carriage optical assembly backward until you can reach the lamp.
  • Remove the two screws from the top of the optical assembly that covers the bulb and remove the black cover.
  • Lift the lamp from the socket, working one end, then the other.
  • Replace the lamp with a replacement lamp. One replacement lamp is provided with the scanner and others are available through Agfa Parts Order.
  • Return the lamp cover the original position and replace the two screws.
  • Replace the plastic housing and replace the four screws holding the housing.
  • Thread the ribbon cable of the Transparency Option through the base and plug back into the SCSI board.
  • Return the board to the base and tighten the two screws. This insures a slack cable that won't be punctured when screws are put in to attach the transparency module to the base unit.
  • Replace the two screws in the back of the base to secure the Transparency Option to the base.
  • Popular Solutions for Agfa Arcus II Flatbed Scanner
    Questions and Unsolved Problems for Agfa Arcus II Flatbed Scanner
    Do you recommend Agfa Arcus II Flatbed Scanner?
    Answer
    Answer
    I have an Arcus II Flatbed Scanner that I was using on a Power Mac. I purchased a new G4 Mac and... (More)
    Answer
    Hi can someone help I have losted my transparency template which the book says ' be sure this... (More)
    Answer
    This Scanner is awesome--- however, when going to scan from my Apple G3 today a Dialogue box... (More)
    Answer
    Troubleshooting Agfa Arcus II Flatbed Scanner rattles when..attempt to scan. This scanner was workig... (More)
    Answer
    I have Arcus II Scanner SCSI interface I would like to update driver to work on 10.4 OS Mac I would... (More)
    Describe your Scanners problem:
    Ask our Experts
    Solve Your Problem Now!
    Chat Live with an Expert
    Chat Now
    Top Scanner Experts
    Top Printer Repairmen
    in Van Nuys, CA
    (800) 836-9287
    Celebrating 14 Years Of Outstanding Printer Repair...
    Laser Repair 911
    (918) 583-5483
    Elite printer Services, Inc. is a full service HP...
    Elite Printer Services
    Chat Now
    Insert Link
    Insert Image
    Insert You-Tube clip
    Insert List
    Insert List
    Spell Check
    What is this?
    Select
