Question about Seagate TapeStor 240 (STDL-62401LW) (STDL62401LW) DAT Tape Drive
Seagate stdl62401LW Hello... Is it possible to erase tapes in this drive without it being connected to a computer??  I want to erase in masse, a bunch of old tapes.
  • 244 Answers
No there should be a software to drive in erasing data you must plug-in to the computer before you can operate well.
Hope you like my solution please rate me solved!
Best regards,
Posted on Nov 17, 2007
I am using the seagate external memory with my dish reciver to back up movies I have recorded was going to add some more but I get an error message saying there is a problem with the transfer also all of...
I would have to assume that a "Seagate external memory" is actually a Hard Drive. If so then you need to note what sort of Port or interface connection it is using. USB / Firewire or a direct connection cable of some sort. Note also the size (capacity) of the drive. You have probably loaded it up so full that it can't function.
The ideal situation would be to connect this drive to a computer and try and recover your files. You need to know what the drive was formatted for. Check the manual. Was it Fat32, NTFS, Mac OS Extended (Journaled) etc or some proprietary receiver format.
Does the dish receiver have the format (erase) utility on board. If the PC or Mac can see the drive on a USB port then you may be able to recover your movies.
If not... You can always format the drive or completely erase all data and set it up for use again. Or you can replace the drive with any number of different brands of drive, maybe even with larger capacity.
Most drives all use ATA or the newer SATA type connector internally. They are all interchangeable. So WD (WesternDigital) Hitachi, Seagate, etc will all work the same way. (All of them have to be able to plug in to different brands of computers. Mac or PC.
Without further info, it's hard to suggest anything else.
Good Luck
Aug 05, 2014 | Seagate Computers & Internet
How connect ext mass storage Seagate FreeAgent GoFlex Net to LAN through router by TCP/IP
Here is the link to the pdf for your Go flex.
This is an excerpt from the file concerning NOT using the pogoplug...
Accessing GoFlex Net Without Using the Pogoplug Service (Windows)
You can access the drives connected to GoFlex Net without using the Pogoplug Web
interface. Follow these steps to set up local network access.
1. On the Windows taskbar, click Start > Network or right-click My Network Places >
An Explorer window opens showing all computers on your network.
2. Locate and then double-click the computer name associated with GoFlex Net.
NOTE: Your GoFlex Net name starts with the letters "FADS" followed by the last six
alphanumeric characters of its MAC address. This 12 digit address, preceded by "MAC:",
is printed on the label on the bottom of GoFlex Net.
You can now access each drive connected to GoFlex Net. Access is regulated by the file
sharing permissions you set using the Pogoplug service.
Hope this helps...
Nov 01, 2012 | Seagate FreeAgent® GoFlex? Black 1TB...
How to write to a seagate hard drive from a mac
you will need to reformat the seagate drive if it has not been formatted for do this.
connect your seagate drive to the mac.go to spotlight the magify glass at the top right corner and type in disk utility and select disk utility
in disk utility make sure you select the seagate hard drive and choose erase. at the middle of the screen look for format and choose mac os extended. click erase.
you should now be able to write files to your seagate drive.
also if you would like be able to transfer files to and from a mac or PC then you will need to format the drive as FAT.
Feb 15, 2012 | Seagate 1TB FreeAgent USB 2.0 External...
Hello - I have a SeaGate Free Agent Go 880 GB external hard drive ... with 3000 pictures of the first year of my twins' lives! I have only used this hard drive once ... to back up all of the pictures from...
> the backup volume is read-only
This means that you should try to copy all the pictures from the device onto your computer's disk-drive, while you still can!
Or, select a bunch of images, and burn them to CD/DVD-writable disks. Select another bunch, and repeat.
Sep 17, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
My computer does not see my external hard dive
Go to this webpage (Seagate) and choose from the SeaTools and FreeAgent Drivers that are appropriate for your OS and particular model. Formatting the harddrive should not have caused this problem of not being connected, but it is possible there was a piece of software that communicated with the computer that was removed via the format.
Apr 06, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
How do I install my seagate freeagent external harddrive into my macbook? my computer keeps asking whether I want to erase everything on the hard drive first. I'm afraid it will erase any software that...
the soft ware that comes with it will also be erased, as it is a windows based identification,seagate free agent has mac utilities on its site, try to find out on you will find one for mac format and mac installation .
Dec 02, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Seagate drive doesn't recognize tape media.
please try to use cleaning cartridge. if tape drive is still in failure. perhaps the heads is bad.
Feb 23, 2009 | Seagate Travan TapeStor Travan Tape Drive
Seagate external hard drive problem
Hello, Did you try to use this drive on another computer? Did you have the same problem? Did you try using a different cable? I would try these things first in order to determine if the problem is with the drive or with the computer. Good Luck! Dr. Know
Dec 23, 2007 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate TapeStor 240 (STDL-62401LW) (STDL62401LW) DAT Tape Drive Logo
81 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
