Question about Motorola Mobility RAZR V3
Ireceived the above Motorola Mobile i would like to the seller regarding it itss fully charged and I can get the screen up its a present. I use an android phone
Motorola Fire XT (XT530) charging problem .
Motorola FIRE XT Tips for extending battery life
Back to Previous Page
Are there any tips on how to extend the battery life?
Things you should know about charging your battery.
New batteries are not fully charged. Plug the battery charger into your phone and an electrical outlet. Your phone might take several seconds to start charging the battery.
Tips:
  • It may take several charging cycles for your battery to reach optimum performance.
  • The battery charger shipped with this device is designed specifically for Motorola mobile phones. Other chargers might take longer to charge your battery, or cause your calls to fail during charging.
  • You can charge your phone via USB cable but this charging time will vary based on computer specifications.
Tips to extend battery life:
  • Select a shorter backlight duration
  • Lower the display brightness
  • Use the AC adapter to charge your phone whenever possible
  • Turn Bluetooth off when not in use
  • Turn Wi-Fi off when not in use
  • Close any third party applications running in the background
  • Playing music, videos and viewing images in your phone will affect your battery life
General Battery use & safety
  • Motorola recommends you always use Motorola-branded batteries and chargers. The warranty does not cover damage caused by non-Motorola batteries and/or chargers.
    Caution: Use of an unqualified battery or charger may present a risk of fire, explosion, leakage, or other hazard. Improper battery use, or use of a damaged battery, may result in a fire, explosion, or other hazard.
  • Your battery can be charged without it being fully depleted, and can be charged every day if desired.
  • Battery usage by children should be supervised.
  • Important: Motorola mobile devices are designed to work best with qualified batteries. If you see a message on your display such as Invalid Battery, Invalid Charger or Unable to Charge, take the following steps:
    • Remove the battery and inspect it to confirm that it bears a Motorola "Original Equipment" hologram;
    • If there is no hologram, the battery is not a qualified battery
    • If there is a hologram, replace the battery and retry charging it
    • If the message remains, contact a Motorola Authorized Service Center
  • New batteries or batteries stored for a long time may take more time to charge.
  • Charging precautions: When charging your battery, keep it near room temperature. Never expose batteries to temperatures below 0°C (32°F) or above 45°C (113°F) when charging. Always take your mobile device with you when you leave your vehicle
  • When storing your battery, keep it in a cool, dry place.
  • It is normal over time for battery life to decrease, and for the battery to exhibit shorter runtime between charges or require more frequent or longer charging times. Motorola batteries are designed to last between 350-700 charge/discharge cycles at room temperature. This amounts to approximately a year to a year and a half of battery use for most people.
  • Avoid damage to battery and mobile device. Do not disassemble, open, crush, bend, deform, puncture, shred, or submerge the battery or mobile device. Avoid dropping the battery or mobile device, especially on a hard surface. If your battery or mobile device has been subjected to such damage, take it to a local service center before using. Do not attempt to dry it with an appliance or heat source, such as a hair dryer or microwave oven.
  • Use care when handling a charged battery-particularly when placing it inside a pocket, purse, or other container with metal objects. Contact with metal objects (such as jewelry, keys, beaded chains) could complete an electrical circuit (short circuit), causing the battery to become very hot, which could cause damage or injury.
Apr 17, 2014 | Motorola Mobility XT530 Fire XT Black...
Motorola Defy cannot be used on ear speaker only on loudspeaker
You see, it seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around the internet state that it might be caused by usage of the wired headset, but it could be nothing more than pure speculation. Anyway, Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them by new ones. So, you must send yours to be repaired, under warranty. Please, contact either the store or seller you bought your phone from, or Motorola, directly, for further details
Well, a possible workaround for this issue is to consider using either the wired (original) headset or a bluetooth one for phone calls.
Really hope you are able to have your phone fully funcioning pretty soon. This phone is pretty amazing!
Regards,
Carlos
Sep 25, 2011 | Motorola Mobility Defy Cell Phone
Ear speaker not working ,only loud speaker works.
Well, a possible workaround for this issue is to use the wired (original) or a bluetooth headset for phone calls.
Regards,
Carlos
Aug 28, 2011 | Motorola Mobility Defy Cell Phone
My motorola defy when calling and receving calls I can here the person unless its on speaker phone
You see, it seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around the internet state that it might be caused by usage of the wired headset, but it might be nothing more than speculation. Anyway, Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them by new ones. So, you must send yours to be repaired, under warranty. Contact either the store or seller you bought your phone from, or Motorola, directly, for further details
Regards,
Carlos
Aug 14, 2011 | Motorola Mobility Defy Cell Phone
Hi i have a motorola defy when i make a call or reseive a call i cant hear anything unless i put my phone on hands free
You see, it seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around the internet state that it might be caused by usage of the wired headset. Anyway, Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them by new ones. So, you must send yours to be repaired, under warranty. Contact either the store or seller you bought your phone from, or Motorola, directly, for further details
Anyway, a possible workaround for this issue is to use the wired (original) or a bluetooth headset for phone calls.
Regards,
Carlos
Jun 13, 2011 | Motorola Mobility Defy Cell Phone
My MC55 will not respond to a cold or warm boot. I have fully charged the battery. The screen will not respond when I tap it. The screen is white withe the Motorola logo and MC55 Series. Is there...
My MC55 will not respond to a cold or warm boot. I have fully charged the battery. The screen will not respond when I tap it. The screen is white withe the Motorola logo and MC55 Series. Is there anyway to get this back to working again with out sending it to a tech person?
Can you help me?
Jun 05, 2011 | Motorola MC55 Handheld Mobile Computer PN...
I have a motorola defy which I can't hear the other person on the other end of the line unless I place the unit on speaker phone. Is there a setting that needs to be adjusted or is the unit faulty...
It seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around the internet state that it might be caused by usage of the wired headset. Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them by new ones. So, you must send yours to be repaired, under warranty. Contact either the store or seller you bought your phone from, or Motorola, directly, for further details
Anyway, a possible workaround for this issue is to use a bluetooth headset for phone calls.
Regards, Carlos
May 20, 2011 | Motorola Mobility Defy Cell Phone
Hi, I cannot hear conversations unless I have the speaker on.
It seems that some early batches of this phone are more prone to present this issue. It's a hardware problem. Some posts around state that it might be caused by usage of the wired headset. Motorola is aware of this problem, and they seem to be either fixing faulty phones or replacing them for new ones. So, you must send yours to be repaired, under warranty. Contact either the seller you bought your phone from, or Motorola, for further details
Regards, Carlos
May 03, 2011 | Motorola Mobility Defy Cell Phone
A couple of days ago I found the only way i could talk out or hear incoming was to switch to speakerphone
Regards, Carlos
Apr 04, 2011 | Motorola Mobility Defy Cell Phone
Fully charged cellphone battery drains in a few minutes
relpace your mobile battery and avoid overcharging and charging overnight
May 22, 2009 | Motorola Mobility MOTORAZR maxx V6...
Motorola Mobility RAZR V3 Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Mark Magill
Mark Magill
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
