Question about Kenmore Dryers
E 1 COAD KENMORE DRIER - Kenmore Dryers
  • 6,784 Answers
E1 flashes in the numeric display when the temperature sensing circuit is open. Replace temperature sensor if faulty.
Posted on Jul 13, 2009
Why does drier stop midcycle and need 30 minutes before restart?
OH OH sounds like a bad motor with bad motor windings u can try disconnecting the belt and drum and run motor by itself see how it does then
Aug 30, 2014 | Kenmore Dryers
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
Won't heat
There could be a number of different reasons for your drier not to be heating. You could start off with making sure your getting 240v to your drier. Then you could check the lint trap outside your house to make sure its not clogged. If all is good you will now have to take apart the drier and with a ohm meter check several parts. Heating element, burnt wire, limit switches, and a few others depending on the model. If your familiar with troubleshooting you can find a schematic on your drier and go from there. If not I would recommend you having a technician to come and check it.
Oct 26, 2012 | Kenmore Dryers
The controls locked button is on. What does that mean? The drier does not work. What can I do? I have a kenmore HE2 drier
Press and hold the End Of Cycle Signal button for 3 seconds to turn this feature off. Hope this helped Tim
Nov 06, 2010 | Kenmore Dryers
Have kenmore dryer the pilot is out
it probably has a glow plug not a pilot, tun on the drier and watch for 15 seconds to see if a glow is visible, Not knowing the year or type of drier makes this hard to reply to, but if you do see no glow,, check the main fuse (thermo) at the rear of the unit and replace
Aug 02, 2010 | Kenmore Dryers
Drier shuts off after a few minutes
Sounds like you have thermostat problems, try to replace your thermostats
Sep 25, 2009 | Kenmore 63942 Dryer
Drier tumbles but will not heat up, checked for
check you legs on the plug it might have a bad leg (prong) or you need a new pig.
Jun 05, 2009 | Kenmore Dryers
My kenmore dryer will run then stop after a few minutes
this sounds like it is overheating all driers have a thermatic switch that will kill the drier if it over heats, probably wouldnt hurt to call out a repairman from sears on this one.
Dec 31, 2008 | Kenmore 62602 Electric Dryer
Opened dryer door mid-cycle left open 1 hr. Dryer won't restart
there is a door switch on left upper corner of drier opening, make sure the little prong is clicking when you push it in. this turns the drier back on when the door is closed and the start button is pushed.
Dec 31, 2008 | Kenmore 63942 Dryer
KENMORE DRYER
the only thing that can burn in a drier is lint most of the time if lints building up in a drier depending on age its because of poor venting if the drier heats but it takes longer than an hour to dry clothes you have a vent restriction but every few years you should take it appart and clean it out now kenmores drums run on rubber wheels and like a car they get flat spots in them so they roar and bump when they first start but should get quiter as you run more loads during the day
Dec 29, 2007 | Kenmore 63942 Dryer
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
