Question about Kenmore Dryers
Front loading kenmore 86983110 makes loud noise when turned on. Think that there is a problem with the belt. I am tryng to take it apart now and do not know how to find the belt
  • Kenmore Master
  • 19,396 Answers
The belt is located at the back of the appliance.
To remove belt you have to remove a panel at the back, on some model you remove top panel first.
The belt does not make loud noise. Loud noise when spinning is usually caused by bad drum bearing, located at the back of the drum.
Regards.
Posted on Jul 13, 2009
Kenmore he3 dryer front load knocking noise
Check the tensioner pulley that keeps the belt tight. It is next to the motor and the bearing may be shot.
Mar 08, 2014 | Kenmore Dryers
Over loaded my front load lg washer and now it is not able to spin. Makes awful grinding noise. Is this something I can fix myself?
this hapened to me years ago it was an easy fix I took apart my washer ther should be a belt that almost looks like a belt off a car it probably went off track once you get it apart try spinning the belt you should be able to fix yourself
Jul 06, 2012 | Kenmore HE2 Plus Front Load Washer
My front load washer is making a loud noise and think it is the motor, i took the front bottom panel off and the sound was coming from the what looks like motor i guess not sure what to do
Remove the rear panel . remove belt . turn drum pully if you hear any noise it is the rear drum bearing and seal . Reach inside drum from front and lift up on inner drum. If this drum moves up and down or side to side you will also need to replace the inner drum. If turning the drum is silent try turning the motor if it makes a noise replace the motor
Oct 29, 2010 | Frigidaire ATF6000ES Front Load Washer
Kenmore electric dryer making loud noise when running
It sounds like the belt that goes around the drum. I have a similar Kenmore, and I get that same rotational thumping noise. The belt is probably about to break or come apart. If you take it off and run it trough your hands, I think that you'll find either belt separation, or a bad spot missing a chunk.
Fortunately the belt is a cheap item. I've kept my Kenmore dryer running over 20 years now.
Mar 18, 2017 | Kenmore Dryers
Our front loading Kenmore MODEL 41742042100.has begun sounding like a jet enjine when it is spinning,someone told me that it is probably bad bearings, is it worth having this 7yr old machine repaired or...
Hi.
I
f you get a very loud noise coming from the machine, and this noise islouder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, probably drum bearing spider had broken.
On a front load the drum bearing is located at the back of the drum.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
You can find parts and diagrams for most models here.
Nov 13, 2009 | Kenmore 44042 Front Load Washer
Makes loud noise during the spin cycle.
no loud noises water will drain, just belt broke plastic piece needs to come off so I can replace belt.
Sep 13, 2009 | Kenmore Elite 45986 Front Load Washer
Loud noise kenmore washer
  • Hi,
  • try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 22, 2009 | Kenmore Washing Machines
Kenmore front load washer
My Kenmore front-load washer starts to make the huge noise. The noise happens during the wash cycle, but is mild. During the spin cycle, the noise becomes really loud. It looks like the drum is getting loose and hitting other part of the machine.
I checked the drum, and I can sway the drum easily with my hand. So it looks some supporting structure is broken. I don't know if it is easy to open the washer to check what has been broken.
May 20, 2008 | Kenmore 44072 Front Load Washer
Loud noise, I think the belt
Take front of dryer .. 2 clips one on each side of dryer front.. once you get front of u will be able to see belt and look to see how front drum support comes off... post if you need futher help
this is a link to some diagrams that may help u
http://www.pcappliancerepair.com/model-display.php
Oct 14, 2007 | Maytag PYE2300AY Electric Dryer
Dryers Logo
198 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
