Everytime i sew machine squeaks i've cleaned the parts stated in the manual what to do next?
If your Kenmore is an older mechanical machine, it most likely needs a good oiling. Consult your owner's manual maintenance section for instructions. Use only fresh, good quality sewing machine oil. Apply only one or two drops each place in the instructions. Do NOT oil plastic or rubber parts/belts.
Hello Shirlene, If your Kenmore machine has two drive belts, a belt from the motor to an idler pulley and a belt from the idler pulley to the main shaft. I have found that the idler pulley needs some Teflon grease on the idler pulley shaft. On my machine, the squeak would go away for a while if I oiled this idler pulley shaft. But it was short lived. Only grease on the idler pulley shaft would silence the squeak.
