Question about Panasonic KX-T7453 Corded Phone
I need to clear all programming from phone
When trying to use line 2 it comes up invalid. switched phone to another location and it still doesn't work so somebody tried programming the phone and we have no clue as to how to clear it out or set it to default
    Novelist:
  • 201 Answers
Your phone KX-T7453 can be used on several different Panasonic phone systems that program and set up very differently. You will need to determine which Panasonic phone system you have.
Is this happening on just one phone location or all phones on the system?
If you have a programming manual for your phone system you could make changes or default it if you want to but you should make sure a default is what you want. If you have voice mail or if you have the system set up very differently than default you would be creating a lot of work by defaulting the system. Not even knowing your setup I would highly suggest trying to fix the problem as it is instead of defaulting.
Posted on Nov 16, 2007
I just installed a replacement At&t EP 5962 2 line, answering answering device telephone. Line 2 does not get a dial tone. I installed it into proper / same as before outlets and both lines light...
There may be damage to the wiring of line 2 (either in the building or on the phone). Are both lines wired to one jack or are they separate? Do you have any other jacks that have line 2 connected (preferably as single line jack) in the building?
I like to use an old single line corded phone that does not use a power adapter. (As long as the EP5962 corded base will work without power (POTS), it might work for the tests below. You might want a simpler phone to carry around.)
If the lines have separate jacks, try switching line 1 and line 2. (Connect your Line 2 jack to the Line 1 input on the phone and vice versa.) If line 2 doesn't give a dial tone when connected to line 1, see the next set of tests. Otherwise, contact AT&T if the phone is under warranty. These phones are not meant to be user-serviced. Alternatively, plug in a different phone to the line 2 jack to test for dial tone.
Next move to another jack with line 2. Check if you have dial tone at that point. (If you do, you know the problem is at the first jack or the wiring to the jack.)
If there is no dial tone at the next jack or you do not have another jack for the line, find where your telephone service comes in. Open the service box and determine the type of connections in the box. If you are lucky, you will find RJ-11 jacks for the incoming service. Plug in your test phone and check for dial tone. If you have no dial tone or can't check the service, then contact your telephone company. They will test your line and fix it free if the probIem is outside.
If you have a dial tone, then it's an inside wiring problem. Inspect the visible wires for damage. Open the faceplates for the jacks and check for loose wires. There are two types of connectors. Screw type connectors need the wire stripped back a little then wrap around the screw and tighten. The other type is a punchdown jack. To repair a loose wire in this, you will need a punchdown tool. These are often available in hardware/home improvement stores in the wiring section. http://www.lanshack.com/wire_phone_jack.aspx has clear pictures of the wire color to pin pattern.
You may want a professional to check the wires inside the walls. Your phone company will fix problems for a fee.
Damaged DSL filters on one line could be the cause. Similarly certain animals may have chewed on the specific wires somewhere in the line.
I hope this helps.
Jul 23, 2011 | AT&T EP5962 Phone
What to do when you insert a sim on nokia n97 and it says invalid sim?
You go to your cell phone provider and buy a valid sim card. Either the card you are putting in the phone, is not compatible with the phone. Or the card your putting in the phone is from another provider and wont work in that phone - (the sim cards may look the same but that doesn't mean that they are programmed alike)
If your not trying your sim in a different phone and your getting the invalid sim error then it means that your sim card is no longer active or valid and you need to contact your cell phone provider to find out why.
Jul 13, 2011 | Computers & Internet
I got msg "check operator
Go to your phone settings and locate (line 1/ Line 2) function...switch the Line 2 to Line 1 then ok....now turn phone of and on an try it...
(if this doesn't work the first time ...change line 1 to Line 2.)
this will stop the problem..
www.joestechreview.ning.com
May 12, 2011 | Apple iPhone 3G Black Smartphone
We used to have a guy come in whenever we had phone problems but he retired. One of my co-workers somehow tried to transfer a person to one of our other locations but in the process have put lines 1 and 5...
When you transfer a call from the outside to an outside place, it will use two external lines for the duration of the call. Sounds like there the PBX is not configured for "disconnect supervision," (DS) meaning that it can't detect when the call finished on either side, so it holds those lines in use. Even if you set DS up on the PBX, the telephone company be sure the lines are programmed for COD (clear on disconnect).
If you do external transfers, you need to set up disconnect supervision on the PBX and COD from the telephone company.
This will probably involve the services of a professional, unless you are comfortable navigating the
internal menus of the PBX.
You can clear the lines by disconnecting the amphenol connector for the outside lines for a few seconds and reconnecting it (which will disconnect all outbound calls) or by rebooting the PBX.
Mar 21, 2011 | NorStar M7310 Corded Phone
I was storing some extension numbers and spead dial numbers and I must have done something wrong as anytime I pick up handset to make a call a 'reorder tone' message comes up on the display- this is before...
So don't pick up the handset :-)
There are some line preference and pickup dial programs that just happen to sit in PROGRAM 1x. My guess is that you have assigned an empty or invalid pickup dial code to the phone.
Try this first. Press PROGRAM and dial 12 ENTER. Is the Hot Line mode ON? If it is, press SEL and ENTER. Wow. That was easy :-)
Didn't work? Let's go for Preferred Line Outgoing next. Dial PROGRAM 19 and 3 ENTER. That makes the intercom prime (0 is none, 1 is idle line 2 (xx) is a specific line).
If you tried both of these, and still no joy, then it's time to reset the phone. The problem with that is you have to dial the code IMMEDIATELY as you're picking up the handset. Good luck with that. The reset code is 79# or 790.
Carl
Jan 25, 2011 | Panasonic KX-T7630 Corded Phone
We have an error 49.2 F83 come up on our HPLJ 4015n, How do I fix this and what is causing this?
Thank you for contacting FixYa with your printer inquiry.
The LJ4015 Series printers are the latest upgrade of HP's most reliable LJ4000 series printer. . 49.xx errors are usually firmware, formatter, or sometimes print-job related.
The first step in troubleshooting this error is to isolate the printer from any computer source - disconnect from any I/O ports, Network/USB etc... Power cycle the printer. Does the error still report? If NO then an application may be causing the error, try to isolate the file causing the problem. Clear any pending print jobs. If YES then Firmware/Formatter most are the problem. The newest firmware is version 04.046.2A released in early September.
Critical Firmware Error.
Causes are invalid print commands, corrupt data, invalid operations or even a bad formatter.Power cycle the printer. Press STOP to clear the print job from memory.
Power cycle again. Try printing something from a different software program. If it works, print the job that failed before. If it still fails, repeat the power cycling again and then print something using the failing program but a different file. If it works the file that failed before is corrupt.
If it fails no matter what you print, your printer has a hardware problem and would suggest going to HP for warranty. Try updating the firmware.
Formatter issue. I would attempt a cold reset if that doesn't resolve it then you are going to have to replace the formatter.
How to cold reset a P4015
Turn the machine off (Remove the Jet Direct Card - Retains IP Address)
1- Turn the Machine on.
2- Press and Hold The OK button until the memory stops counting and all 3 lights are lit up.
3- Arrow up to cold reset then hit OK to start the reset.
If the machine still comes back to the 49 error after the reset the formatter will need to be replaced. Formatter Part Number - CB438-67901 for HP LaserJet P4015x (HP CB511A)
Hope this helps. Please keep us updated and remember to rate this answer.
TF
Feb 26, 2010 | HP LaserJet P4015N Printer
C:\program\SAGE\ACCOUNTS\REPORTS\\*TB.SRT contains an invalid pat
This message usually comes when the target location is not there or is renamed OR the address is wrong. Open My Computer, and go to the address you gave. Look if there is the file named *TB.SRT.
And by the way... the address you gave was "
C:\PROGRAM\\SAGE\ACCOUNTS\REPORTS\\*TB.SRT" BUT I believe that the address should be "C:\PROGRAM\SAGE\ACCOUNTS\REPORTS\*TB.SRT".
It is not possible that the address contains 2 slash (\\) repeatedly. Open the file by going to the My Computer OR by opening the software and by locating the file manually from there.
live chat assistance costs $19.99. And $12.99 for one time e-mail premium support.
If you have a registered product then I would suggest you to visit:
http://support.sage.co.uk/default.aspx?page=1
There you might find a solution at no cost.
Please inform if your problem is solved or not. And please rate if you found the above info useful.
Aug 28, 2009 | Sage Instant Accounts 8.0 (013604ug)
Reprogramming a business phone
You will need a professional comdial dealer to reprogram it for you.
If in NY area contact Foritas.net or AAA-Avad.com
Mar 18, 2009 | Comdial 8024-S Impact 24-Line Phone
HELP!!!!!!!!!!!!!!!
comment débloqué le code de vérouillage
Sep 29, 2008 | Motorola Mobility RAZR V3x Cellular Phone
Clear speed dial/one touch settings
There is no way to clear the settings you would have to re-program the correct setting. Did you program one touch speed dial on the line buttons? I do not see how programming a speed dial could effect accessing the CO lines unless you re-programmed the CO line buttons by mistake. If so, you would need to re-program those soft keys to line buttons. The manual you have may not cover this? The phone you have can work on a few different Panasonic phone systems. If you need a more detailed manual you will first need to know which Panasonic phone system you have. The phone part number WILL NOT help you determine which phone system you have. There is a main control unit somewhere (basement, utility closet, etc..)
Aug 13, 2007 | Panasonic KX-T7431 Corded Phone
Panasonic KX-T7453 Corded Phone Logo
128 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
