Question about Acme Automotive A750HH50 Flexeel Air Hose 1/2" X 50ft., With 1/2" Reusable Fittings
Where are the spark plugs located on odyssey 2004 ?
  • 110 Answers
They are under the ignition coils on the 3.5L.
Posted on May 09, 2010
2004 honda odyssey flasher unit relay location how do you install a flasher relay in 2004 honda odyssey
Your vehicle might not have a flasher relay.
Vehicles using a CAN-bus system often use a single ECU to carry out all vehicle functions where timing is required - flashers and hazard flashers, courtesy light, wiper delay, etc.
I suggest you check a wiring diagram for your car to discover what system it has.
Oct 23, 2016 | 2004 Honda Odyssey
How many hours of labor on average is it to replace the cam shaft position sensor on a 2004 Honda Odyssey
2 or more. There's a lot of stuff in the way that has to be disassembled to get to the sensor
Jul 16, 2014 | 2004 Honda Odyssey
Spark plugs gap
no engine stated? wow. 3.5L? says no gap settings.
its in the FSM. many cars dont put it in the op guide as the plugs
are rated to 80k miles or more, and is not consider, operator deal.
sadly.
and many folks think the new plugs are set in the factory , WRONG. (comment is for J plugs not surface fire tech)
i see you are there.!
many stores, list it wrongly too.... vast....
but you never said country car was sold.
in the USA we open the hood, look up and behold, its right there.
the vacuum and turn up sticker,
now alldata.com
quotes to follow.........all.
the original equipment spark plugs installed in the Odyssey 3.5L V-6 engine are platinum tip spark plugs, and the plug gap must not be adjusted.
and other warnings, and the no file them warn.g
On CR-V and 4-cylinder Odyssey models, adjust the spark plug gap to 0.039-0.043 inches (1.0-1.1mm). On Odysseys with the V6 engine, check, but do not adjust the spark plug gap. The spark plug gap should be 0.039-0.043 inches (1.0-1.1mm). If the spark plug gap exceeds 0.051inches (1.3mm), replace the spark plug.
so 1mm , if not v6
Sep 07, 2013 | 2000 Honda Odyssey
P0302 misfire dectective
This means a misfire is detected on spark plug 2. I could be a bad plug, plug wire, coil if it has that. Anyway it is the second spark plug.
Aug 19, 2013 | 2002 Honda Odyssey
I can't find wha the gap shold be on the spark plugs for my 2005 honda odyessey
The recommended spark plug gap for a 2005 Honda Odyssey is .044"
Oct 15, 2012 | 2005 Honda Odyssey
What is gap setting for autolite double platinum spark plugs for 2003 Honda 3.5 engine?
Hello there:
The recommended spark plug gap for a 2003-2004 Honda Odyssey is .044"
Keep in mind, many OE manufacturers (i.e. Denso, NGK) pre-gap their plugs for specific applications. If you happen to buy the iridium or platinum style plugs with the very thin center electrode, they should come pre-gapped. It can't hurt to check the gap before installing the plugs, but if any adjustment is necessary, do so with caution because the ultra-thin electrode may crack if any excessive pressure is placed on it.
Hope this is very helpful
Best regards Michael
Aug 07, 2010 | 2003 Honda Odyssey
Location of sparkplug on 2004 Honda Odyssey EX and replacement
the spark plugs are located under the coil packs they have one or two bolts holding each one in. you have six cylinder so there should be six coil packs three facing you when you pop hood and three more located towards the back. let me know if you have any other questions.
Jul 02, 2010 | 2004 Honda Odyssey
I have a 2004 Honda Odyssey multiplt missfires (tcs/engine light)
It sounds like fuel starved at higher speeds. i would change the fuel filter first if this does'nt help check the fuel pressure
Jun 18, 2010 | 2004 Honda Odyssey
How to change plugs on honda odyssey 2005
you will need
8mm
10mm
5/8 spark plug socket
3/8 ratchet
3/8 extension (it could be 4in and longer)
and spark plugs factory plugs are pregap iridium
spark plug torque is 13.0 lb.ft
coil torque 8.7 lbf.ft
spark plug part # NGK 1zfr5k-11
# DENSO pkj16dr-m11
and spark plug anti seize on spark plug thread
what you need to do is remove the plastic cover 8mm socket or 10mm sockets
now remove the spark plug covers and remove the spark plug coils too 10mm head bolt you will need a 5/8 spark plug socket and a 3/8 ratchet and a 3/8's extension too
you need OEM spark plugs they work the best
hope this will help
May 22, 2010 | 2005 Honda Odyssey
Acme Automotive A750HH50 Flexeel Air Hose 1/2" X 50ft., With 1/2" Reusable Fittings Logo
Top Acme Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you an Acme Tool and Hardware - Other Expert? Answer questions, earn points and help others
