Question about Magellan Roadmate 1200 Car GPS Receiver
I have a magellan 1200 ... it stopped working on a trip one hour from home. it said battery low.. I had it plugged in. I purchased a charger from a super store outlet and tried to charge it ... still no luck... what wrong. My unit isn't that old. I haven't used it very often only on trips. this is seldom. What's wrong?
I had the exact same problem. The GPS does not longer switch on, I have also bought a new charger and still does not work. I have also plugged it in my computer, but nothing still doesnt work...please help...my GPS is about 18 months old and I use it very often...thanks
Posted on Jul 22, 2009
    Problem Solver:
  • 6 Answers
I can try to help...
Did you try pluging it into your computer with the USB cable? What happens when you do this?
Posted on Jul 17, 2009
Magellan RoadMate won't compute if connected to power
unplug the charger, then turn the 1200 on, once its fully booted, hold the power button for 15 seconds..the screen will go blank after a few seconds, but continue to hold it for 15 seconds.
now, with the charger plugged in and unit off, press and hold the power button for upto 7 seconds or till it starts.
if that fails, let me know and i can tell you something else to do.
bill
Jan 23, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My garmin nuvi, which I purchased less than two months ago, no longer loads. It appears to start up with the introductory screen then goes blank. The charger is hooked up and is apparently working.
the battery is either to low or shot,
plug it in to either the home charger, car charger or usb for a few hours and try it again. once it starts, go in the gps main menu and see what the battery meter tells you (what does it look like, is the meter moving ect)
Jan 23, 2010 | GPS
Update for Magellan RoadMate 1200
when driving after approx. 1 hour. I get an error message that says my SD card has been removed. Any suggestions?
Jan 20, 2010 | Magellan Roadmate 1200 Car GPS Receiver
My magellan roadmate 1200 will not turn on
make sure green light is on if using the car charger and let it plugged in for awhile, then hold the power button (up to ten seconds) until it starts..
if you tried charging it with both house charger and car charger and tried to start it like i explain and it still will not start, its most likely a bad power port which is very common with this model and many other magellan models.
Sep 10, 2009 | Magellan RoadMate 1200 GPS Receiver
My roadmate 1200 will not come on battery is charged and I have hit the reset button any Ideas
plug it in to either the home charger or the car charger for a few minutes,(is the green light on, on the car charger) then press the power button for up to 15 seconds.if that fails, try a hard reset. little pin hole on the side(use a paper clip) if that fails you might have a bad usb connector.
Aug 06, 2009 | Magellan GPS
Magellan Roadmate 1200 won't lock onto any satellites. Satellite tracking is zero. Worked two days perfectly, day three, nothing. Brisco
check that your battery is fully charged use an AC charger if you have one.
Check Baud rate and port are set in accordance with manual
Jul 26, 2009 | Magellan Roadmate 1200 Car GPS Receiver
The battery will not charge on my magellan 1200
try hold the power button for upto 15 seconds but i suspect the power port might be damaged due to magellans poor design, you can contact them here
Jul 21, 2009 | Magellan Roadmate 1200 Car GPS Receiver
How to replace battery in magellan 2000
I reached a destination using the megallan 2200 T on car charger. But when started back after four hours, it was not working at all. I don't know what to do with it.
Oct 31, 2008 | Magellan RoadMate 2200T GPS Receiver
My magellan 1200 will not keep a charge when i plug it in...it will not turn on cause the battery is dead...when i plug in the charger to the unit it flashes a bright white light for like a fraction of a...
I agree. I suggest you should go to a technician and try a new battery. If the new battery does not work you should speak to your manufacturer.
Thanks for using FixYa!
Oct 17, 2008 | Magellan GPS
Magellan Roadmate 1200 Car GPS Receiver Logo
363 people viewed this question
Top Magellan GPS Experts
Jungle Ghost
Jungle Ghost
Are you a Magellan GPS Expert? Answer questions, earn points and help others
