Question about Cannon Mag 10ts Tournament Series Electronic Downrigger
Cannon magnum 10a downrigger tripping breaker
Cannon 10a downrigger trips circut and i just put a new board in it before i put the new board in it would go down but not come up. i also drew my wiring and put it back the same the board in it originally was dated 1994. thanks
4 Suggested Answers
mikesreel
  • 76 Answers
SOURCE: Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Posted on Sep 27, 2009
mikesreel
  • 76 Answers
SOURCE: cannon digitrol manual lost..
Heeere you go!
DT IV Manual
Best of luck
Mike
SOURCE: cannon downrigger
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
Posted on Aug 09, 2010
Trips breaker
I would suggest looking at the heating element for current leakage
Apr 04, 2014 | LG WM2655HVA 3.6 Cu. Ft. Graphite Steel...
I have a rodgerblack gold treadmill ag-10302 when i switch it on at wall it trips the circut in my fuse box help please
1) please use a table lamp in connect in wall circuit. if the c.breaker trip again, the problem is your outlet wall. Call electrician or test the wires for touch each other or ground improperly, and fix it.
If the circuit is NOT trip, test the power cord for defective 2) test the main switch for shot circuit 3) test the c. breaker for defective 4) test the motor see the if the motor if short circuit see my personal TIPS for help motor , see the diagram attached. 5) test the output board, the board can be short circuit and replaced. Happy NEW YEAR God bless you
Dec 31, 2012 | Reebok Exercise & Fitness
Breaker tripping
This could be a heating element issue. it could be a bad element. Disconnect the two leads going to the heating element and then turn the breaker back on. If it will run and not trip the breaker then you have found the problem.
On the heater tube there is a silver sticker that will have the information you need to identify what model heater you have and what the kw of the element is. It will either be 4 Kw or 5.5 Kw
You may contact us for more information about this or purchase the replacement element at www.uspartscenter.com
Nov 09, 2012 | Garden
After pre heating oven, unit tripped the circut breaker. After re-setting breaker, all but the oven bake cycle worked. Now after about 2 hours, all seems fine. What caused the circut breaker to trip?
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor. To solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Nov 14, 2011 | Ovens
Compressor will not start without tripping breaker?
Circut breakers trip due to a short circut or an overload. In this case the likely cause is an overload. If your compressor is drawing more amperage than the breaker is designed to allow, the breaker trips for safety. Possible solutions. Try using a different outlet with fewer appliances or tools on that circut. If the outlet you are using is on a circut that also has lighting, appliances etc, each item is drawing amps, the addition of the compressor to the circut is pushing the amp limit over the top. You can also try a heavier duty extension cord. If you are using an extension that is rated too low for the required amperage your breaker will trip. If you are not using an extiension cord you may need to talk to an electrician about adding another circut to service your tool and garage needs.
Another possiblity is that your service is not upgraded enough. If you have a 60amp service for the house you might want to talk to an electrician about upgrading to 100amp or more.
Jan 04, 2011 | Garden
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
Used (older) Cannon Digitroll II Manual or advice
I have the quick start manual for digi-trol II. I will try to scan it and post later today.
Kevin
Jun 20, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
LG LRM2060ST trips circuit breaker sometimes
needs to have circuit of its own rated @ 20 amps powered by # 12-2-wg wire , also very good idea to plug into a good surge protector to protect its control board, as any computer the boards are very susceptible to spike voltage caused by lightning and power problems , as to how it worked before , breakers vary a little in the amount of current it takes to trip them with age , the number of time they have to be reset and heat they have been subjected to over a period of time so it is not unusual for say one 20 amp breaker to trip @ 16 and another @19 for example also the length of wire between the breaker and the appliance can effect the trip range
Jan 13, 2009 | LG Microwave Ovens
Cannon Mag 10ts Tournament Series Electronic Downrigger Logo
526 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
