SOURCE: hotpoint washer mod # vbxr1070w1ww
hi thanks for the question i would check the lid switch on that washer very common problem thanks the appliance doc
SOURCE: very low brake pedal
It is very possible there is still air in the system, as ABS systems can be awkward.
This may be a case of taking it in to a garage - just to "change the fluid", as a vacuum type filler may be needed to put things right.
SOURCE: I have a leaking banjo fitting on vw t5
YOU CAN REPLACE THE BANJO WASHERS IF THEY ARE LEAKING.
