I Transferred a hd into this pc from another pc. This hd is ntfs format.The second hd in this pc is the fat format. In explorer it shows the second hd as the d drive. When i click on it it says this hd is not formatted,which it is. I could access it before swapping hd's Why does it ask to format it when it has files on it and does work?
  • 1 more comment
  • bbpar117 Jul 14, 2009
    Opps, sorry for the confusion. the present pc (A), which is a generic model, has win xp pro and two hd's. The hd in it is from another pc (B)which also has 2 hd's. It is also win xp pro. I took the hd from the(B) pc because the cpu fans where not cooling right and it shut down. It has a AMD cpu. This pc (B) has a Pentium cpu. So,before the swap I could access the second hd in this pc (A). Now, I can see the hd listed in explore but when I click on it a window comes up and says it is not formatted and would I like to format it now. Of course I do not because it has data on it.
    So, why does it want to format the second hd and why can it not be read? This hd is the ntfs format and the second is the fat format. The reason for this is the way they were setup. Both came from two different people. Any ideas?
  • Dave Ferrell May 11, 2010
    What model computer? What kind/size are the drives? Are they both Windows partitioned? How old is hte drive? This one has a solution, but it needs more information.
  • Hank May 11, 2010
    Hi, More information is needed. What operating system is on your pc and which drive is it on? Windows 95 or 98 can't access ntfs format. Xp likes to have both ntfs or both fat. You can not have two operating systems on two different hard drives without dual booting software.
  • 358 Answers
First of all, I hope the harddisk which has the operating system on it, and which the system is booting from is NTFS formatted. Try and crosscheck this first. Then after doing this, try and assign a new drive letter to the harddrive that is showing error from the Systems Management Page.
This is how you do that : Right-Click on My Computer Icon, Go to Manage, Click on Disk Management, Then when you get to this place, You should see ALL the HardDrives installed on your system including the one singing for "format me"...lol.
Then locate and right-click on the harddrive, and select "Change Drive letter and Paths", and select any new, unique letter for your HDDrive. then click on OK.
Hope this helps.
Goodluck.
Posted on Jul 13, 2009
My 128 GB microSD card is restricted to 16 MB after formating it.
Try to format on a PC and make sure you select NTFS and not FAT32.
Hth.
Apr 21, 2017 | Cameras
Hi What partition file system does a HD PVR 2 P use to operated is it FAT 32 or NTFS
Your PVR will format a new drive. Go into the Hard Drive management section and there should be a "Format Drive" option.
Dec 06, 2016 | Computers & Internet
What format should I chose to grab it to a PC?
This will depend on which type of computer and operating system you have
if you are referring to formatting your hard drive to a specific format file system NTFS or FAT choose the Ntsf file system is more secure Ntfs is more powerful than Fat or Fat32 and includes features required for hosting Directory as well as other important security features . You can use features such as Active Directory and Domain - based security only by choosing Ntfs your file system Its easy to convert Partitions to Ntfs . The set up programs conversion makes it easy whether your partitions used Fat or Fat32 or the older version of Ntfs .This kind of conversion keeps your files intact (unlike formatting a partition). If you do not need to keep your files intact and you have a FAT or FAT32 partition, it is recommended that you format the partition with NTFS rather than convert from FAT or FAT32. Formatting a partition erases all data on the partition and allows you to start with a clean drive.
hope this helps you
Sep 03, 2011 | Computers & Internet
I need to replace the (failed) HD with a Seagate 80GB which is currently formatted FAT32. Is this OK or do I need to reformat as NTFS? Using WinXP
I'd use NTFS but you can make up your own mind here....
http://www.microsoft.com/resources/documentation/windows/xp/all/proddocs/en-us/choosing_between_ntfs_fat_and_fat32.mspx?mfr=true
If you have old computers that need to access files on yours go FAT or FAT32. If you intend to or would like to add huge hard drives in the future (over 2 TB) go NTFS.
Regards
TickMagnet
Aug 19, 2011 | Dell Dimension 2400 PC Desktop
I have a 230 gb FreeAgent Go external drive.
I think the solution that meeknotweak gave is a little bit twisted. First and foremost you can not be able to format a 230gb hard drive as a FAT or even FAT32 simply because that FAT and FAT32 is only set to be used and can be used only if your drive is less than 40gb. If your drive is larger than 40gb then the only option is to format it using NTFS.
Second you can be able to format and set the volume format of the drive under the ERASE tab of the DiscUtility on Mac. Not in "RAID" tab.
This is the right way to do it......
If you plan to use the external HD into a PC or Mac, you should first plug it into a Mac Computer and format it using the Disc Utility. Choose the Erase Tab and select Volume Fomat. Make sure that you choose MS DOS. Only Mac OS can format a drive of any size to a FAT file system. If you have already formatted it you can now be able to use it vice versa.
One more thing if the HD is formatted as NTFS, Mac OS can read it but can't write on the drive. So that's why you need to make it as a FAT so that it would be readable and writable to both OS. Also make sure that the folders and files that you're transferring into the HD doesn't contain special characters. Mac OS can recognize those special characters on a file but windows can't.
I hope this clarifies everything.
Aug 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How do I change the External HD File System From NTFS to Fat 32
back up the data
re format the drive from my computer..
then begin anew..
you know about the file size limitations of 'FAT, yes..
Oct 14, 2008 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
I am unable to format my Maxtor One Touch III 500gig External Hard Drive. Once i get to 100% using ms disk manager, a message box pops up saying that it was unable to format the hard drive. In linux when i...
If it shows up in windows explorer as a drive, right click it and choose format and choose ntfs as the file format.
Do you know what format it is when you use linux? I dont think you can use a dos command to format an ntfs volume. Your message probably means it cant read FAT or FAT32 because it probably already is NTFS file format.
Mar 22, 2008 | Computers & Internet
Help retrieving files from simpletech 320gb hard drive!
I have to admit I haven't used a Mac since high-school, but I can tell you that my first thought on this problem was "file system".
Most external HD's are formatted to be used on a Windows PC, and many are even formatted as NTFS. If this is the case, last I heard anyways, Mac OS doesn't support NTFS.
My suggestion is to use either machine to format the external HD (**you will lose all data on it**) as a neutral file system. By that I mean one which will work on both operating systems.
I could be wrong about this, and Mac OS may support NTFS, but if that's the case somone will be kind enough to correct me.
Mar 15, 2008 | Computers & Internet
Memory card of nokia n72
its better to buy a new cellphone and memory card mama
Feb 13, 2008 | Nokia N72 Cellular Phone
Drive errors running fat 32, is fat neede or can i convert to ntfs?
I'm pretty sure you can convert. You don't need the partitions, but they can be useful. For instance, I just save all of my documents on a partition (and I make the target the partition so it saves it there without me having to do it manually). Then when ever you format (it's good to format at least once every two years if not more) you don't have to back up your documents as long as you leave your partition alone.
Dec 05, 2007 | Acer TravelMate 302XCi Tablet PC
Computers & Internet Logo
67 people viewed this question
David Payne
David Payne
