SOURCE: sanyo phone cutting off
I've seen this happen with corrosion that damaged only the calling part apparently. If you're not inssured you can open it up and look for it, should be visible. If you want to clean it, don't use any solvents or non distilled water. an eraser works sometimes. Good luck
SOURCE: N70 M voice transmission problem
lo m8 sounds like ur mic is faulty or possibly u could have a software problem.try to replace your mic or get ur fone reprogramed.if you dont want to try your self then try these guys they good an cheap. http://www.mobilephoneservicecentre.co.uk/
SOURCE: Strawberry Chocolate low volume
if you have tried raising the volume while on a call and you still have the same trouble then I'm afraid your earpiece has failed and you will need to take it to a tech and have the earpiece replaced
SOURCE: can't hear person talking on razor
remove the batery with out turn it off that may restore the default settings
the vibrator can be replaced and then you need to have the flexcable replaced.....this will correct the issue
