Question about Craftsman 25cc Gas Line Trimmer
Same problem on Homelite leaf blower
Primer bulb pushs in but will not come out.
  • 211 Answers
SOURCE: leaf blower will not continue running unless primer bulb is pushed intermittently
Hi
Priming the engine(put some gas in the sparkplug hole)..If.Start the engine.If only the gas from the cilinder is burned change the lines prom primer bulb.
best regards savumihai71
Posted on Dec 05, 2008
SOURCE: craftsman leaf blower, primer bulb will not return, won't start
primer bulb on weedeater will not return to normal or **** gas into it. new primer bulb. lines to tank have been repalce and can blow through them but primer bulb will not push air into tank
Posted on Aug 21, 2009
SOURCE: Problem with primer bulb
Reverse the line connections at the primer bulb. Look carefully, the long port has the line going to the tank, the short port on the bulb will connect with the fuel line to the carb.
Posted on Sep 05, 2009
SOURCE: craftman leaf blower when I press primer bulb I
May be broken fuel lines. Check the gas tank. I have a 30cc craftsman leaf blower model 316794990 that stopped working all the sudden. filled the tank with new 40:1 gas (looked like the neighbor's kid had filled it with regular gas when he finished last week-glad i looked before i starter her up!). Labeled the gas cans and then started the blower. she ran for a while then shut down. opened the fuel tank again and noticed the fuel lines (one green/blue, one orange) had broken off the connector in the fuel tank wall. SO, if you see loose fuel lines in your gas tank, you''ll need to order the fuel tank assembly. $25 plus shipping. i have one one the way and called to verify that it includes the fuel lines. Good luck.
Posted on Sep 06, 2009
#1 Taper
  • 1040 Answers
SOURCE: Craftsman leaf blower Model # 358794761
Sounds like you have dirt in carburetor.
Check the fuel lines for cracks/breaks. If they are o.k., then:
You will need to disassemble the carburetor and spray with carb.cleaner.Make sure the small screen is free of debris. (Should be able to see daylight through it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance on:
1. Fuel line replacement or
2. Carburetor kit replacement
Just let me know.
Jim
Posted on Nov 27, 2009
Backpack II. How do I replace the primer bulb?
  1. Homelite Blower UT08072 User's Guide ' ManualsOnline.com
    lawnandgarden.manualsonline.com > ... > Homelite Blower OPERATOR'S MANUAL. BACKPACKER II. UT08072 and UT08572. SAVE THISMANUAL FOR FUTURE REFERENCE. Your blower has been engineered and ...
Jul 20, 2015 | Homelite Garden
NEED PART # FOR PRIMER BULB ON HOMELITE BP30185
Thanks for providing the UT number.
When cross reference the carburetor part of up00651 it came as as Zama C1U-H36 which has a Zama 0057003 which is superceded to Zama 0057030
Mar 18, 2015 | Homelite Backpack Leaf Blower
Homelite ut-08068-r leaf blower leaking fuel
If we are talking about a hand held leaf blower. The fuel leaking from the carb is likely caused by a stiff metering diaghram holding the needle open. Rebuild your carb ( I suggest also replacing the fuel lines and primer bulb while you are at it) and double check the lever adjustment.
Oct 23, 2012 | Homelite Garden
I have a handheld blower/vac: The primer bulb is new and will not pump fuel,not even fill the bulb. I checked the fuel lines to make sure they were correct.(homelite)
I was working on a neighbor's homelite chainsaw and I replaced the primer bulb, it was not intuitive, and I hooked up the lines backwards. Also if you are replacing the primer bulb, maybe you have old fuel lines that are deteriorating and need replaced. Did you check the in tank fuel filter? If it looks dark, it may be time to change it.
I hope this helps get you going again.
Sep 01, 2011 | Homelite Consumer Products MightyLite...
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Dec 21, 2010 | Homelite Garden
Primer bulb is cracked on my Homelite Blower/VAC Model HB-180 Gas is leaking, I need replacement parts. Blower purchased in 1990
www.homelite.com to buy parts online
1.800.242.4672 customer service #
both will give you your local shop. Home depot also sells homelite products.
Apr 24, 2010 | Garden
PRIMER BULB WONT PRIME
I would recheck the carburetor to make sure you put the diaphragms next to the carburetor and not the gaskets.
Please if it is not priming you may have the fuel lines hooked up wrong. Also check the fuel cap to make sure the vent assembly is there. If the tank is not venting, the tank will get a vacuum in it not allowing fuel to flow.
HTH
Good Day.
Nov 11, 2009 | Homelite 'Yard Broom' Leaf Blower
Plastic dome used to prime has hole
The primer ball can be bought at any local mower shop. Just ask for a primer bulb. Remove the screws (usually 2) next to the bulb and remove the plate around the bulb and it should pop right out.
Sep 27, 2009 | Homelite 'Yard Broom' Leaf Blower
Homelite blower UT08111 the bubble for the primer will not push
Remove and disassemble carberator clean with gumout solvent (wear safety glasses when spraying) blow out all small holes and passages in carb then reassemble check primer bulb function.
Sep 11, 2009 | Garden
Craftsman 25cc Gas Line Trimmer Logo
211 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
