Dvd player doesn't work. says file not found.
  • 55 Answers
The lence is bad you have to change the lence or get another dvd.
Posted on Jul 13, 2009
How can I get my dvd to copy videos when it reads, No Disk? when there's a disk in the player?
hi, possible problem with the dvd, the lens doesn't read the disc or the spindle motor not rotating that is why can not read a disc. try to clean first with a cd lens cleaner, just insert a cleaner to the player to remove dirt and might the lens get sticky. now if still doesn't work, you will need to remove the cover of the player to access the internal part. check for broken part or any obstacle that can block the rotation of the spindle motor.if the motor doesn't rotate anymore you can check the resistance if still there using an analog tester. if no resistance at the pin terminal of the motor, the coil was worn out then you will need to replace the motor.
Jun 08, 2012 | Compaq Computers & Internet
Hello trying to upgrade my HCT HBR-1000BP Blu-ray Player firmware and can not figure out how. No support on HCT website. Would be thankful for any help
Where are you having a problem? I found directions on: http://hcthk.com/mall/s02.php . There were two links, one with directions and one with an arrow for downloading the needed file.
The firmware is in a zip file. First extract the files from the compressed archived. (For a Windows OS, right click on the folder and select Extract All.) If needed, open the new uncompressed folder and put a blank CD-R or CD-RW in your optical burner drive. Burn the two files from the extracted folder to the CD (drag and drop will work for any version of Windows (XP-7).) Do not include the folder, just the files. Then finalize the disc (close the session). If you are asked to format the disc, choose a mastered burn (single-session). In Windows Explorer, you can do this by right-clicking on the optical drive in Computer (My Computer) or from the menu for the drive when you double-click on it. (Alternatively, if you have your system set to finalize on eject, then choose Eject. This setting is in the drive's Properties (the Recording tab).)
Eject the disc from your computer and turn on the HBR-1000BP. Place the CD that you burned in the player. When the disc is recognized, press Play. If that doesn't work, try entering the System Menu and choosing System Update with your remote. Do not power down the unit during the update; a power failure during the update might leave you with an unusable player.
If this doesn't work, check if the Blu-ray Player reads any CDs. If it doesn't, try cleaning the laser lens with a CD/DVD lens cleaner. Then try again. The Blu-ray uses a different laser. If no disc works and the lens cleaner doesn't help, the CD/DVD laser has a tracking (alignment) issue or another problem. You'll need to get the optical drive in the HBR-1000BP replaced or fixed.
If it does read a different CD, then check if your optical disc burned and was finalized correctly. Can another optical drive read it? Try burning the files to CD on another optical drive. (If you are using an external optical drive burner, make sure that the computer is not running on battery power. Plug the external drive into two USB ports if it isn't self-powered.)
I hope this helps.
Mar 31, 2012 | Televison & Video
I need codes for a Symphonic DVD player...
Found this by google:
Symphonic DVD/CD player Model WF-104 worked with Comcast Cable remote
with code 0675
- If this doesn't help post the Model name too.
Jul 29, 2011 | Televison & Video
I downloaded the firmware for my DVP3580 dvd player from the Philips website and unzipped it to a usb stick. It shows up on the stick as a VLC video file (VLC is a programme I normally use to watch...
You may want to load the update to a CD and try it. The web site should have good instruction on either load device. I had to go to my System Setup on the TV screen to make it work.
Jul 22, 2011 | Philips DVP3982 DVD Player
I have an LG BD650 player that it's not able to play divx videos because "video format not supported." The specs of the player indicate otherwise.
I had the same problem with certain .avi files. I did a lot of research and found a program called "FourCC Changer". You can google it and download it for free. Open the file that doesn't work and change the "fourcc" to "xvid". Once I did that, the .avi files played without a problem. I hope this works for you. Good luck!
Jul 03, 2011 | LG BD650 BluRay Player
The player won't play dvd movies.
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck.
May 13, 2011 | Jwin JDVD703 Portable DVD Player with...
Hi, I have a Samsung DVD Player H1080 R. Nice player with sleek design. When I try to connect my Seagate Go Flex USB 2.0 Plug & Play (1 TB), it doesnt play. There is data in the external hard disk,...
Good day!
These are the 2 possible causes and solution on that problem:
  • The format of the file on U.S.B device is not compatible to the format requirements of the DVD player.For example your DVD player required A.V.I or MPG/M-PEG for the video while the file format of your U.S.B is F.L.V and when you try to insert it to the U.S.B port the file doesn't read.You have to do is convert the file that store on your U.S.B device depends on the format requirement of your DVD.Use a total video converter to convert the file on your U.S.B to the format you need to play on the DVD player.
  • Or the problem could be the U.S.B itself,because the U.S.B host on this product does not supported all U.S.B device.Please try to use other mass media device such as memory card or mp3 players.
I hope this solution will be helpful.Thank you.
May 02, 2011 | Samsung DVD-H1080R DVD Player
Does not play divx/mpeg4 files on dvd disk!!
The player plays strictly DIVX files, but not variants like XVID (which today is more common since divx became not free).
Divx is actually the same than XVID. After spending days converting my files from xvid to divx, realized that changing only the FOURCC code of the files works.
Look for a program named videoinspector. It allows to edit the fourcc for a video file. for all xvid and variants change the fourcc of the files to DIVX. The change takes a second instead hours of conversion, and movies in xvid that used not to play on this device, now will be played without problems.
Apr 08, 2009 | Philips DCP851 Portable DVD Player
Want to unlock Panasonic dvd player A120
Multi-Region:
Power On the player
Open the tray
Press 9, 8, 1, 7 on the remote
Press Enter until the display indicates Region 9
Press Return
Note: Region 9 = All Regions
Heres the one i know for this player. The enter key might be named 'ok' on other remotes.
Hope this helps.
Dec 14, 2008 | Panasonic DVD-A120 DVD Player
Making my Samsung HD870 a multi-regional Player
this player is known for not being able to be downgraded. The player needs to see a .bin file and there is remote code to input to flash it.
Jan 02, 2008 | Samsung DVD-HD870 DVD Player
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
