Question about Dremel Variable - Speed Multipro Rotary Tool 395
My Dremel 395 type 4 does not run until I spin the chuck and then only runs at high speed.
  • 2,176 Answers
Sounds like a switch or brushes. You can go to Dremel.com and they have a toll free number for their tech services and you can also download a breakdown for this tool.
Posted on Sep 21, 2009
I need a new chuck.
Lowes, home depot and Sears sell them. Also, dremel.com sells parts.
Jun 24, 2014 | Dremel Variable - Speed Multipro Rotary...
The blade assembly on my dremel will not come off. Is there a trick to this?The coupling seems to stuck.
Try some W-D40 and gentle hits on the coupling to liberate the chuck 3 pin holders.If you got this type of chuck:
r00130v1.jpg > Enlarge Image
4486 Dremel Chuck
The Dremel Chuck holds Dremel accessories without using a collet eliminating having to use the wrench and creating quick and e
Nov 08, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Unit wont run at all, yes I do have power, took apart and 1 of the brushes was stuck in slot and it looks like its been really hot.do I need to replace the switch assy. dremel 395 type 4,
I would think that just the brushes, they should slide freely in the slot. check also the condition of the armature for arcing or raised commutator bars.
Aug 07, 2010 | Dremel Variable - Speed Multipro Rotary...
Dremel moto tool model 395 coupling from motor to
The part that goes between the motor and the chuck is called the CLUTCH UNIT,
REF 2615294309 it is a splined rubberised sleeve, it also fits the 276 and 396.
The price is £3.69 (including vat at17.5%) and can be obtained from Jaymac (Derby) Ltd.
http://www.dremel-direct.com/acatalog/service.html
Jul 19, 2010 | Dremel 395 Variable Speed Multipro Rotary...
Motor works but no drive to shaft.
My 15 year old Dremel 395 had the same problem so I took it apart. There is a plastic spline between the motor and the output shaft to the chuck . My plastic spline was split and had many of its teeth sheared off. The shaft lock acts on the output shaft side of this spline, so it was ok. Otherwise everything looked great; bearings ran free & had little play free, brushes ok. To be fair, my Dremel had seen hard use & doesn't owe me anything. No luck so far finding replacement spline parts, which if available should be easy to install. To take apart your tool, just google "Dremel Disassembly". GOOD LUCK!
Nov 28, 2009 | Dremel Variable - Speed Multipro Rotary...
The variable speed switch on my dremel 395, can I get rep. parts
The part number you need is 2610945681 variable speed switch. I checked a couple site with no luck but I suggest you call Dremel at 1-800-437-3635 and order direct. Good luck
Jan 09, 2009 | Dremel Variable - Speed Multipro Rotary...
Variable Speed Does Not Work - Model 395
It probably can be replaced. For info on this tool call 1-800-437-3635 (Dremel) and speak with customer service about a replacement part. Hope this helps
Oct 12, 2008 | Dremel Variable - Speed Multipro Rotary...
Dremel Variable - Speed Multipro Rotary Tool 395 Logo
449 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
