Question about Samsung LN-T4042H 40 in. LCD HDTV
My LCD TV Samsung, doesn't power on immediately. It clicks several times and finaly after 15 minutes the TV gets On. It is frustrating. I beleive many othere do have the same problem.
    President:
  • 2,777 Answers
I would first suggest you try to unplug the device for an hour or so as this many times resets them, and they work after that. It's the easiest (and free) solution, so I always suggest that you start here.
If this doesn't work (you may have already tried it even) I think it's time for a service call. Make sure you don't have your display plugged into other devices that might be switching off power (like triggered receivers, etc.) or a circuit that's being over-loaded with other things on the line.
Also, if you have other Samsung components and using Anynet+, might try disabling that in the display as well as the other components. I avoid any proprietary features like that. They often cause as many problems as advantages.
However, I am pretty sure you are having a power supply fault issue, for whatever reason it is very common with Samsung TV's... you will probably end up having to call Samsung and schedule a service visit, the good news is that in most cases this can be fixed for less than $100.
Samsung's contact information for support is: 800-726-7864
Hope this helps, thanks for your time,
Tim G
Posted on Jul 13, 2009
Tv turns on for 10 seconds and then turns off. Then a red flashing blinks 6 times and repeats
Search Results
    Samsung TV On/Off Issue - Repair - Instructables
    www.instructables.com/id/Samsung-TV-OnOff-Issue-Repair/
    InstructablesThe result of this issue is a TV that will cycle between on and off repeatedly and/or an annoying clicking noise while turning on. Time to get informed about the ...
    Easy fix for new Samsung TV switching on and off power ...
    ? 4:41
    https://www.youtube.com/watch?v=H0cG3lzjuw8
    Sep 15, 2012 - Uploaded by alwaysafix
    www.alwaysafix.com Find the correct TV part for your TV and more at ShopJimmy.com Click Here: http ...
    Samsung 46" LCD TV (LNT4665F) turns off and on over again - Forums ...
    www.cnet.com > Forums > Samsung
    CNETAbout 3-4 months ago, my TV would start turning off and on a few times at startup but eventually would stay on after a couple of minutes. Every once in a...
    Samsung TV turning off [Solved] - Samsung - Displays - Tom
Jan 19, 2016 | Televison & Video
My Samsung 46 inch LN550j1fxza LCD TV turns on and plays sometime but then shuts back off with no sound, black screen and won't come back on until it's off for a while. thank you
CNETJun 11, 2015 - About 3-4 months ago, my TV would start turning off and on a few times at startup ... Samsung 46" LCD TV (LNT4665F) turns off and on over again ...chirp would sound and then it would power off and the cycle would continue. ... After 5-10 minutes of this without being able to shut it off completely, I pulled out the power cord. Samsung UN55B8500 - turns off by itself! - Forums - CNET
Nov 16, 2011
Samsung LN46A650 green/pink static picture and power resets ...
Jul 27, 2010
More results from www.cnet.com
How to fix clicking samsung tv (wont turn on) - Instructables
www.instructables.com/.../How-to-fix-clicking-samsung-tv-...
Instructablesif your looking at this then you probably have a samsung tv thats broken. This instructable is for how to fix one of the most common faults in samsung LCD tvs. .....its fine and never goes off until it is shut off but will not turn on immediately . ... The issue with my LN46A650A1F just started happening last weekend (12/7/2014).
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ON AND OFF Repairing Samsung LCD No power problem LN ... LCD No power problem LN MODEL LN46B500 - buy the cap kit for your tv model ...
Jan 05, 2016 | Samsung Televison & Video
SAMSUNG LE40S86BDX WONT SWITCH ON JUST CLICKING AND RED STANDBY LIGHT FLASHING
hello,
Clicking and not switched on because capacitors on pcb power have damage.
open and change the capacitors can solved your problem.
if any problem after replacing capaditors, let me know . thanks
Mar 28, 2011 | Samsung LCD-TV LE40S81B 40 in. HD-Ready...
I have a 52" 1080p 120 Hz LCD HD Samsung TV that
You have a problem on your Power supply board, possibly a bad capacitor or loose connection. You can look hard at your power board and check for these things or replace it from places like shopjimmy.com or discount-merchant.com etc
Jan 19, 2011 | Samsung LN-T4671F 46 in. LCD Television
Samsung LNT4661FX/XAA 46 in. HDTV LCD Television - When tv is turned on it makes a clicking noise for about 15-16 clicks. When it finally comes on it has purple dots all over the screen. Unplug the tv for...
Got to Samsung's support site and fill out a request:
http://www.samsung.com/us/support/service/request
You will be contacted by your regional repair center. I'm located in Milwaukee, WI and was contacted by a repair center in Elgin, IL, which is 60 miles away.
The regional center said they think it probably is a electrolytic capacitor issues, as multiple models of Samsung LCD's have this issue. They have defective (too low voltage) capacitors which will eventually give out. Unfortunately he said my model was not on the list they have for a free fix. He gave me the number to Samsung's Executive Customer Relations department, which I then called immediately. The woman there checked and found that my model indeed was covered - she updated the Support Request, and instructed me to call back the regional repair center.
I called back the regional repair center (immediately after finsihing with the ECR) and got a different person on the phone, and gave them my ticket number from my original request. He said since ECR updated it stating my model was covered they would fix it for free. If it's not the capacitors that are causing the problem I will be charged a 150$ fee, plus any parts required to fix the TV. I agreed to that since my local TV repair quoted me 200$ to fix the capacitor issue alone.
Today is January 25th, they have me scheduled to have a repair tech come to my place January 7th to do the repair.
You can fix the capacitors yourself for very cheap, maybe 20-30 bucks if you don't have anything: soldering gun/solder/flux/capacitors/etc...
I'd just go through the service request path, get it fixed for free and have a professional do it. Total time for me was 2 minutes for the service request, 10 minutes on phone for regional repair center, 10 minutes for ECR, 5 minutes for regional again. The repair is expected to take 15 minutes - most likely they'll just swap out the entire power supply board rather than the individual capacitors. Basically 1 hour of time to save minimally 150-250 dollars. I bet not many people asking to fix this make 150 bucks an hour...pretty simple math I think.
-Ryan
Jan 03, 2010 | Samsung LN-T4661F 46 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
The Samsung LCD tv clicking and not turning on for up to 15 minutes with the clicking continuing
The main board or power supply has problem. To make sure which one causes malfunction the TV must be opened and check by technician.
Nov 12, 2009 | Samsung LN-S4051D 40 in. LCD Television
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Circuit diagram Samsung LE23R88BDX - LCD TV
when I turn off and then Turn on after 10 minutes the TV notwork(by using remote or touch button). I try to disconnect power supply andthen reconnect and waiting a couple of minutes and turn on but no work (nosound and black desktop) .I repeat this procedure many times so some timework and sometimes not work. please help me to solve this problem
Feb 24, 2009 | Samsung Televison & Video
Clicks on and off several times before staying on
The power supply will sense if the set is 'drawing' too much current and switch itself off. This could be the case here. The power supply board may eventually go completely bad.
Feb 23, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LN-T4042H 40 in. LCD HDTV Logo
125 people viewed this question
Henry  Thomas
Henry Thomas
