Question about U-Line Icemaker
Boat U-line icemaker turns on but not making ice. Don't see any water at the tray and also not cold. The water source is fine.
  • 286 Answers
You wont have water until the thermostat is satisfied. If its not cooling you have another problem. Make sure your fan and compressor is running. If they are then you need a service tech to look at the sealed system. If the fan isnt running then that would turn the compressor off on overload. Then replace the fan.
Posted on Jul 15, 2009
Where do I find the ice maker inlet water valve or solenoid? The valve on the back of my fridge has only one hose going to both the water dispenser and ice maker and the water dispenser works fine.
Since there is water that flows to the water dispenser, the water valve is working. Now, there's a spout that water flows from to the icemaker tray. Look for it. It's located on the back wall inside the freezer and maybe behind the icemaker tray. Check and see if it's frozen. If so, defrost your freezer by turning the temperature gauge to off position. Wait a while until it's defrosted, then turn it back on.
Next, make sure that the metal wire is in down position.
If that doesn't work, your icemaker maybe defective and needs replacement.
Nov 01, 2014 | Maytag MFI2665XEM Stainless Steel
New icemaker with new water valve and still won't make ice
check the setting on the control panel, it may be just turned OFF
Jul 13, 2014 | Frigidaire GLRS264ZA Side by Side...
Jfd2589kes
Locate and check the valve that feeds water to the icemaker.
Jul 04, 2017 | Refrigerators
Undercounter icemaker is cold but does not make ice --no water getting to the ice tray --checked to srr if feed line was blocked and was clear ----will freeze water put into little containers placed in the...
The water solenoid valve controls flow to icemaker you can put 120 volt to it and see if it opens .If it is good then its not getting power when icemaker calls for fill
Jun 22, 2011 | U-Line Icemaker
I have a u-line icemaker in my boat and it will make a tray of ice but will not dispense it without manual intervention. Is there a par that needs to be replaced? Thanks for your help
Have you used the ULine cleaner recently needs to be run through the icemaker every so often (good water every 6 months bad water as needed)
Nov 14, 2010 | U-Line Icemaker
Hss25gfta refridgerator ice maker seems to be stuck on off .It all of the sudden quit making ice and we can't find the solution.It makes water fine
Hi and welcome to FixYa I am Kelly.
The ice maker suddenly no longer making ice can be caused by many things.
1. The freezer section is above 16 F.
a. Usually the cause is ice buildup on the evaporator coils as a result of an automatic defrosting problem.
b. The evaporator fan is not turning at full speed
2. The ice makers thermostat has failed. When the tray reaches 16F temp is closes the circuit and starts the ice maker harvest cycle.
3. The ice maker drive motor has failed.
4. The ice maker heating element has failed.
5. The inlet water valve is allowing water to drip into the ice tray during the freeze period of ice making.
a. You would note that the water fill area of the icemaker would have ice build up. Also in the very back of the ice make tray ice would build up and prevent the sweep fingers from rotating.
b. Usually when the above happens the rubber water inlet tub that goes from the back of the unit to the ice maker is frozen solid internally.
c. You can test this by removing the plastic hose from the rear top area of the unit and placing the upper end of the tub in a bucket for several hours. (ICE MAKER OFF) If you note water in the bucket the water valve is leaking water past the diaphram when the solenoid is supposed to be closed and must be replaced
6. The inlet water valve solenoid coil has failed.
Most appliance parts sources do not sell piece parts for this ice maker. They only sell the complete assembly. Here is one source of many on line sources for just the icemaker.
http://www.appliancepartspros.com/part_details.aspx?part_id=4345120
Should the water valve be leaking water by it is item 800 of this link that is also one source of many online sources: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5203104&diagram_id=24933031#d24933031
Thanks for choosing FixYa.
Kelly
Sep 03, 2010 | Hotpoint Refrigerators
Ice Maker not making ice
Here are some basic tips for ice maker troubleshooting2_bing.gif...
Ice Maker Problems and Ice Maker Troubleshooting
http://www.fixya.com/support/r3876071-ice_maker_problems_ice_maker
heatman101
Jun 08, 2010 | U-Line Icemaker
CLR 2060 Clear Ice Maker
just a guess but did you make sure that the fan under the unit is turning? if you don't get rid of the heat at the condensor the freeze tray can't get cold.
Aug 02, 2008 | U-Line Icemaker
Ice machine not making ice
Hi, everak11,
Three possible solutions for you.
1: No water coming in from inlet valve. Check voltage on inlet if you have voltage and no water then replace valve.
2:Icemaker not cycleing. Lift the arm on the icemaker to shut it off and leave it for about an hour. Come back in and turn the icemake back on by lowering the arm. If the icemaker does not begin a new cycle and the arm start rising then the problem is most likely an icemaker. Replace Icemaker
3:Refrigerator not cold enough. If the freezer is not getting cold enough the icemaker will not cycle. Check the temperature in the freezer and make sure it is getting down to 0 degrees. If not then you may have another problem with your refrigerator. I hope this helps you, Let me know if you have any other questions or symptoms. Mike
May 08, 2008 | Refrigerators
Ice Maker on/off switch has blinking red light, will not produce ice. Manual no help
When you open the freezer door the light should be blinking. When you hold the flipper door shut (on the left hand side) without blocking the beam, the light should stay on solid. If all of this happens then the optics are o.k. If optics are ok then you most likely have a broken motor module on the icemaker and should replace the icemaker thermostat along with it. A bad icemaker thermostat will lead to the module breaking. If you not sure how to replace these parts then I would just replace the whole icemaker. That would be easiest and usually not much more expensive.
Nov 07, 2007 | Whirlpool ED2FHEXN Side by Side...
U-Line Icemaker Logo
144 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
jasbo
jasbo
john h
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
