Losing power when I accelorate.
Fuel filter is the main culprit when you lose power going uphill. Going level or downhill means that the engine doesn't have to work all that hard and doesn't demand much fuel, so a partially clogged filter can usually flow enough to allow the car to run smoothly. Going uphill requires signficantly more fuel, and if the filter is clogged up, it won't be able to flow enough fuel. This will bog the car down and cause you to lose speed. Change your fuel filter.
