Question about Brother LS-2125 Mechanical Sewing Machine
Needle will not pick up thread from bobbin on a Brother's machine
This machine was my mother's and I don't have a manual. I have used several different machines, but never a Brother's machine. I threaded the bobbin like my singer machine and followed the diagram on the hood of the Brothers to thread the machine, but when I manually lower the needle to pull upt the lower thread from the bobbin to begin it doesn't pull up the thread. It doesn't seem to try and catch the thread when looking at the bobbin.
  • 98 Answers
This is going to sound silly but its one of the first things I check for... make sure that the needle is in correctly make sure that the flat side is towards the back as you place it in the needle clamp. better yet take the needled out all together and put a new one in just to be sure that it isnt bend
Posted on May 31, 2010
  • 136 Answers
Machine out of time, take for repair, very dificult to get to the mechanism for repair, better solution find a good used machine from a dealer, better price much better quality
Posted on Aug 26, 2009
  • 15 Answers
SOURCE: bobbin thread won't catch with needle thread
check that the needle is in the right way round i.e. with cut out on the needle facing into the machine. if this is fine then check that as the needle comes back up from the lowest point that it goes to, that the point on the bobbin case passes just above the hole in the needle, i.e. in the middle of the cut out.(if not it needs re timing) if threaded a small loop should appear at this point for the bottom bobbin to catch if not slacken the top thread and try again.
Posted on Sep 07, 2009
jmgldsmth
  • 2005 Answers
SOURCE: I can't raise the bobbin thread. The needle raises before the bobbin thread can 'catch'
readjust the hook to just grab the thread loop as the needle raises it will take a few tries to get the exact setting for the hook (maybe you will see a mark on the hook shaft to show you where the hook's set screw was located before it slipped)
Posted on May 03, 2009
  • 18 Answers
SOURCE: Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Posted on Aug 16, 2009
Tally Girl
  • 1133 Answers
SOURCE: not quite sure, but, cannot get bobbin thread to
First please double check that the flywheel clutch in engaged and not in bobbin winding mode, ie the inner knob is locked by holding outer flywheel and turning inner wheel away from you.
If you remove the needle plate and bobbin cover and turn the flywheel manually can you see the hook rotating at all?
If the needle is going up and down and the rotary hook is not rotating, then my guess will be that the pinon gear down in the free arm area has failed and will need to be replaced. You don't say what model but if it is a star series you should be able to remove the top plate on the free arm by undoing one screw and exposing this area to confirm this. If its a Stella or Lotus it won't be so easy to view. Either way, if its a Swiss made Elna parts are still available and there are serviceman around who can do this repair. If you are in the USA I would suggest you browse www.whitesewingcenter for parts/repair info on Swiss Elnas.
Or try www.sewingpartsonline.com and search by your model number to see the parts available.
Posted on May 16, 2011
bargainbox
  • 1388 Answers
SOURCE: Necchi 544 - won't pick up bobbin thread.
Timing is out...probably due to a recent jam...this is an overview.http://www.sewusa.com/Sewing_Machine_Repair/Sewing%20Machine%20Hook%20Timing.htm
Serviced more than 2 years ago ??
Overdue
Posted on Nov 08, 2011
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
Needle not picking up bobbin thread and it makes funny loud noise
Sometimes both symptoms are a result of a bent, dull, or damaged needle. Try installing a brand new needle.
If it is still not picking up the bobbin thread and making a noise, take it for service. It most likely has a needle/hook timing issue and the noise could be the needle making contact with the needleplate or in the bobbin area. Continued use could cause the needle to break and flying pieces of needle, in most cases, are not a good thing.
Jun 18, 2016 | Brother Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Riccar stretch 500fa Needle won't pick up thread from bobbin
Check to make sure you are using the correct needle for the machine, that it is a brand-new needle, and that is installed facing the correct direction. Other than that, it's quite possible the machine was knocked out of time and needs service.
Apr 07, 2017 | Sewing Machines
My sisters singers brand new Athena sewing machine she just started jusing about 5 or 6 times just stopped picking up the bobbin thread and sewing thread in the material. It is just leaving holes in
Needs a new needle right way around, most likely. And check the threading on both bobbin and top of the machine. It makes a big difference which way the bobbin turns in the bobbin case.
Jan 14, 2014 | Brother CS-8150 Computerized Sewing...
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Threading the bobbin thread
try rethreading the machine top and bobbin--make sure to use every
thread guide
try changing the needle--make sure the needle is turned the right way
and inserted correctly into the needle holder
make sure the bobbin is turned the right way in the bobbin case
and if the machine still will not pick up the bobbin thread it would be a
good idea to have the machine checked to see if the timing is ok.
here is a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Nov 06, 2012 | Singer 7258 Sewing Machine
Brother cs-80 tension issue
Remove the thread from the machine. Install a brand new needle.
ALWAYS RAISE the presser foot and rethread the top thread. Set the upper tension to the midway point.
Insert the bobbin in the bobbin case (make sure it is turning the correct direction) and thread the bobbin tensioner. Install the bobbin case in the machine.
Insert the fabric under the presser foot. Lower the presser foot. While holding the top thread tail with your left hand, manually turn the handwheel (always toward you, never away!) one revolution until the top thread has pulled the bobbin thread up. Raise the presser foot and sweep both threads under the presser foot toward the back (you can use a stiletto, a pencil, or some other tool to sweep the threads). Lower the presser foot, gently hold both thread tails with your left hand and slowly turn the handwheel (either manually or by motor) to form a couple of stitches. Then let go of the thread tails and continue sewing.
If it continues to cause thread nests or you have other issues, then your machine may need service.
Apr 01, 2017 | Brother CS-80
Brother LS-2125 Mechanical Sewing Machine Logo
686 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
