Question about Samsung SyncMaster 171S 17" Flat Panel LCD Monitor
Blank Screen, power light is steady green
I have a 17" samsung LCD monitor model 170s which does not show anything. The power led is steady green. I checked the cable is OK. I tried monitor with other computers and no luck. It looks like an electronic part is not good. Any help or hint would be appreciated.
  • 729 Answers
Re: Blank Screen, power light is steady green
Have you tried adjusting for the brightness and contrast of the monitor. does any menu comes out if you press any buttons of the monitor except power of course!
Posted on Nov 16, 2007
0 characters
3 Points
Monitor is blank. Green power light is on steady.
Self test failed means Monitor is bad.
Check input settings, whether DVI mode is selected.
Dell Monitor has 3 year warranty by default, Contact Dell Techncial support
Jan 13, 2010 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Screen is blank. Green LED power light is
Might be your graphics card, try swapping it out for a new one and see if that works
Oct 09, 2009 | Dell E173FPb 17" TFT LCD Monitor
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Monitor Not Showing A Picture. Light flashes Yellow and Green.
use the onboard graphics instead of a seperate graphics card (if installed) to test the screen.if it still doesn't work then unplug your monitor from the mains supply and plug in again to reset it. i doubt it's your monitor that is the problem though. but look on the back of your pc for another connection for your screen. the onboard graphics connection is normally vertical near your ethernet port and mouse and keyboard inputs.
please rate me and give me a fixya! if it helped.
Apr 05, 2009 | Acer AL1713M 17" LCD Monitor
Samsung Syncmaster 710n no display and no LED light
The power button should be on the FRONT BOTTOM RIGHT. and there should be a little led/light next to it. make sure everything is plugged in correctly and press the power button, the led should light up, and then boot your computer.
Let me know --
If this helped please mark this thread as FixYA
Dec 26, 2008 | Samsung 710N V2 (Ivory) 17 in. Flat Panel...
Acer AL1716 Blank screen & blinking green power LED
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
Oversize Message
run the system on safte mode and then try to manage your screen resolution to minimum and then restart it normally..
dont forget to rate
Jun 20, 2008 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Samsung SyncMaster 171S 17" Flat Panel LCD Monitor Logo
372 people viewed this question
Top Samsung Computer Monitors Experts
Rugeshan Lanka
Rugeshan Lanka
Level 1 Expert
Pieter Vleeshouwers
Lawrence Oravetz
Are you a Samsung Computer Monitor Expert? Answer questions, earn points and help others
