Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
The water and ice dispenser has stopped working.
The unit makes ice and I have replaced the water filter but the actual dispenser has stopped working. It makes no noise when the dispenser lever is depressed.
  • 3,037 Answers
Well, then you are going to have to pull it apart and diagnose whats not working. The following website has a diagram to see all of the parts and where they go. I think either the fuse (part 5) or the motor (part 36 and part 37) are bad and need to be replaced (these part numbers are location numbers in the ice maker section of the site below). If you supply direct voltage to the motor, it should hum or try to move indicating it to be good.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5164987
Benjamin
Posted on Jul 13, 2009
When I changed my filter in my Whirlpool refrigerator, my refrigerator stopped making ice and dispensing water. How do I get it to start back making ice and dispensing water.
If you still have the old filter replace the new with the previous. If all works OK check new filter for blockage or manufacturing defect. Usually most units will work with no filter installed.
It is likely that you have not fully assembled the new filter in the location.
The filter can be removed and there should be no leak and the ice maker and water dispenser should work just like before except the water is not filtered. This feature is available for customers who have whole house filters.
Hope this helps?
Nov 22, 2016 | Whirlpool Refrigerators
[LG Refregerator] Model LFX25961AL water does not dispense and ice is not being made
Make sure the wire guide that pulls up when ice is at full capacity is not accidentally pulled up. (this is above the ice bin in the freezer). Pull back down and should make ice.
Dec 17, 2013 | Refrigerators
Ge profile refrigerator leaking water from bottom when pressing dispencer
The water dispenser tube is getting leaked form in between or its got loose from its actual line.Inspect water dispenser tube from water valve to the end of where the water is getting dispensed.
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 26, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice maker not making ice and water is not flowing
this could be several items so will go down the list in order... 1st you need to make sure you have a good clean filter or that it has been changed recently... sometimes removed and reinstalled will also help... 2nd do you have 120 volts ac current to the water valve when called for water example" someone pushing the water dispenser handle while you test... if you have 120 volts and no water coming you have a bad water valve... if the dispenser is working but the ice maker is not filling with water they do have dual water valves and one side can actually be bad... before shooting the water valve down though if your getting water to the dispenser but not to ice maker make sure the unit is actually calling for water... on most of these ice makers there is a gear motor on the front part of ice maker there will be a white cover over the front of unit remove it and turn gear motor makes sure it is not broke.. is there frozen water in ice maker if so may be the heater on ice maker is bad... if no water again before shooting down water valve make sure the fill tube coming into ice maker is not froze up...if it is froze up most likely you have a weak water valve and needs to be replaced due to not seating properly.... hope this helps hard to diagnose when not sure what all you have already tested or not...
Jan 01, 2011 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator dispenses ice, but does not dispense water?
Unfortunately, the housing that the water filter fits into is also the housing for the solenoid controlled water valve, and that is the most likely failure item.
Mar 29, 2010 | Whirlpool GS6SHAXMQ Side by Side...
Water dispenser stopped working then the tce maker
The fridge isnt getting water check supply line and filter.
Oct 04, 2009 | Kenmore Refrigerators
GE side by side refrigerator: water/ice dispensor
I bought a brand new smartwater replacement filter and after a very short time, my water stopped coming through the door.. took out the new replacement filter and inserted a brand new one .. problem solved.. apparently some of the g.e. smartwater filter replacement cartridges don't have the high enough two plastic inserts which are attached to them at the top of the filter when you screw them on... if you have taken your cartridge in and out a few times, i think it wears down the plastic so it doesn't fit properly and won't put up whatever it is supposed to push up to make the water come through.. I personally think this is a g.e. problem with the replacement filters...
Jan 31, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
26 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
