Question about Jenn-Air Ovens
Oven control panel or display window does not light up anymore. Can't see what temperature oven is at or the time or anything else for that matter.
    Problem Solver:
  • 11 Answers
Could be a fuse or a bad control panel. Unplug the oven, take the panel off of the back and look for fuses. If none, call Maytag or supplier of Jenn-air oven controller for a replacement.
Posted on Jul 13, 2009
Clock light and temp.light fading out.what needs to be fixed
LED clock/temperature light fading an - Appliance Repair Forum
forum.appliancepartspros.com/oven...ranges.../650-led-clock-temperatur...
Aug 20, 2007 - 3 posts - ‎3 authors
The LED clock/temperature/etc control light has been becoming less ... needs to be replaced (board being the oven clock/erc/control board). Control pad temperature light out
Jun 15, 2014
Dim temp lights
Feb 7, 2014
Frigidaire range LED display is dim
Aug 28, 2009
Oven clock & light
1 post
Jun 21, 2009
More results from forum.appliancepartspros.com
Cheap Fix for a Dim Display on an Oven Control Panel ...
Nov 29, 2015 | Whirlpool 30" Self-Cleaning Freestanding...
Wolf ovens getting err message after power outage
I had a Wolf 30F wall oven with a similar problem
after power outage. It wouldnt stop beeping with error message related
to temperature control. My solution was to turn power of at circuit
panel, then reset by pressing and holding the clear button for 5
seconds.
Also note: in my case I had to close the display
before switching the panel off. When I tried to the reset process with
the panel showing, it wouldn\'t reset.
To reset other
various parts of the control panel Instructions said:
Time-of-Day Clock
Immediately after the oven is installed, set
the 12-hour clock to the current time of day. It may need to be reset
after a prolonged power failure. The clock is visible on the control
panel during all modes. If the upper oven timer is set, the clock will
not be visible in the upper oven control panel display.
SETTING CLOCK
1) Touch CLOCK.
2) Touch number pads to
set current time of day.
3) Touch CLOCK or ENTER to start
clock.
24-HOUR CLOCK
The time-of-day clock can be
changed from a 12-hour clock to a 24-hour clock. After the clock has
been set, touch TEMPERATURE for three seconds, touch CLOCK, and then
touch ENTER. Follow the same sequence to change back to the standard
12-hour clock setting.
Fahrenheit to Celsius
The
oven can be changed from Fahrenheit (°F) temperature to Celsius
(°C).
Oct 26, 2012 | Wolf Range Ovens
After I cleaned my oven, I can't get the oven
the heat sensor the controls the oven temp is bad or shorted closed and needs to be changed also the control panel that operates the oven temp could have a bad I C Chip thats went bad and you may need to new control panel
Jan 22, 2010 | Ovens
My clock and temperature display is dim
Hi, this will happen over a period of time and its just heat related. the control panel isn't insulated properly and , there has been a larger than normal transfer of heat to the inside of the control panel where the circuits are housed.
If this is a problem, i recommend replacing the control board. it will fix the dim issue.
May 22, 2009 | Jenn-Air JMW9527C Electric Double Oven
No display on EOC68000 electric oven
flip breaker off then turn back on after a few min.see if that resets panel.if not you will need to call and have the control module replaced.
Mar 11, 2009 | Electrolux EOB5630 Ultrafan Electric...
OVEN CFEF372BC3 electric control panel not working
Look on the control board for fuses. Some fuses don't look like a standard replaceable fuse in a fuse holder. Some are soldered to the control board itself.
Jun 17, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
My oven is in lock mode after i had cleaned it. I can't open it now and the lock light is on.
Control panel and oven door lock
The oven door and controls can be locked to avoid unintended use of the oven. The oven doors and controls cannot be locked if the oven is in use, or the oven temperature is 400°F (205°C) or above. The current time of day will remain in the display when the controls and oven doors are locked.
To lock the control panel and both oven doors:
  1. Press and release Cancel.
  2. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” appears in the display and “Lock” flashes while the controls and oven doors lock. Both oven doors lock. “Lock” remains lit in the display.
To unlock the control panel and both oven doors:
  1. Press and hold upper oven Cancel and Cook & Hold for 3 seconds. “Off” disappears from the display and “Lock” flashes while the controls and oven doors unlock.
Dec 22, 2008 | Jenn-Air Electric Double Oven
F1 code on display pad
That error means the main control board has a internal failure. The board will have to replaced to fix that issue. If you need detailed repair help with that visit the link below:
Appliance Repair Help With Live Chat
Mar 23, 2017 | Amana AOGD2750 Gas Double Oven
Dimming temperature and clock light on display window
I found capacitor c3 (68 uf 35 volt) had leaked and dried up, causing the display to fail. I unsoldered and tested c1, c4, c7, and made sure they were good, using a digital multimeter with the ability to test capacitors. C3 also had visible signs of leakage. Works like a charm again, and the display is bright like new!
Dec 30, 2006 | Thermador SC272T Electric Double Oven
Ovens Logo
332 people viewed this question
Top Jenn-Air Ovens Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
