SOURCE: Panasonic switching to standby mode on its own
Is this a recognised symptom? yes the problem in power supply. it is due to switching oscillator& switcing output circuit probabaly capacitor & transistor. as set is very old so after power supply is ok check for horizontal output also. can it be fixed? yes it is common & not major problem
SOURCE: philips tv
I have a 32 inch phillips tv that I bought from someone else and it has a child lock code on certain channels. How do I get this code off.
SOURCE: we have thomson tv 32" color crt sort length model 29df45 c s /icc20
tv power goes off when vcd / dish receiver is connected
SOURCE: i have a 21inch TV (LG golden eye) which is 10
This is line output transformer problems. Before changing LOT,watch any dry soldering is there and also check vertical output ic is good or bad ?by replacement methode.
NOTE- if you know the protection pin, isolate the pin and switch on tv through 200watts bulb seriesly.then watch the symptomes.
Thanking you
